lumen aeternum
- Joined
- Sep 29, 2012
- Messages
- 897
Blinding someone would be a pretty serious felony.
beats using a knife. depends of where you live. if Id live in the US I wouldn't carry a torch for self defense thats for sure.Blinding someone would be a pretty serious felony.
If he's close enough for a knife, you need a wide beam pattern to dazzle him. You won't be able to aim a narrow diameter beam.beats using a knife. depends of where you live. if Id live in the US I wouldn't carry a torch for self defense thats for sure.
That's a good question. I'd like to know the answer. Not all LEPs use mirrors. There's a second type that allow the beam to go directly through some type of optic and then hit the phosphor if I have understood that correctly. I'm not sure whether they're more robust than the mirror method or not.How robust are LEPs? Are the laser/mirror configurations able to deal with being dropped from waist height or whatever the standard is for LEDs?
Do the lasers units dim over time with use?
( I'm considering buying the Fenix one).
That's interesting to read. Lasers are banned here in the UK, so I don't own any and I am completely ignorant about them, apart from in this new conversion technology. (Albeit, I still don't know much! )I don't know much about lasers really. My reason for posing the question was that I recently noticed that one of the laser modules on a good brand of laser level I own has dimmed noticeably, even though I don't use it very much.
The type of laser may be completely different in LEPs, but it just makes me wonder do they have an Achilles heel?
....Still probably going to buy one all the same.
I use the button top H10 in mine and haven't had any issues. 🤷♂️I am currently trying to find a good battery for my lumintop ant man and I am considering ordering the vapcell H10 online. However the store also provides a "button top" option. I have no idea whatsoever if I should choose this or the non button top battery.
Any suggestions would be greatly appreciated.
So is rape, robbery, and assault. Everyone should have the right to fend off an attack using any means available.Blinding someone would be a pretty serious felony.
Killing someone is illegal too, except in self defense. In any case I'd rather have done something illegal in defense of my life and live, too bad what the law might be or the low life who might be blinded. If you blind someone defending yourself don't tell anyone and escape. I'd only use that as either a sole or last resort though.So is rape, robbery, and assault. Everyone should have the right to fend off an attack using any means available.
Legally, in a self defense situation one has to use an appropriate (not excessive) amount of force to repel an attacker. Meaning the minimum amount of force which promises to be effective. So no, not by any means available, only when warranted though direct and immediate risk to your or others lives.So is rape, robbery, and assault. Everyone should have the right to fend off an attack using any means available.
Deadly force is acceptable when you are in fear for your life or that of another, fear of serious bodily harm for yourself or another (includes rape). If the attacker happens to die will being repelled, that's OK.Legally, in a self defense situation one has to use an appropriate (not excessive) amount of force to repel an attacker. Meaning the minimum amount of force which promises to be effective. So no, not by any means available, only when warranted though direct and immediate risk to your or others lives.
Excitation Wavelength | 440-460nm |
Phosphor Dimensions (The yellow area) | φ3mm/φ1mm |
Total Dimensions | φ8*0.7mm/φ5*0.65mm/φ3*0.65mm |
Base Plate Material | Sapphire |
Color Temperature | 5700K / 6000K / 7000K |
Light Efficiency (Laser to White Light) | 165lm/W@5500K |
Max Working Temperature | 200℃ |
Max Laser Power Density | 7W/mm^2 |
Two separate scientific articles (regarding automotive LEP, as big companies are not interested in flashlights) indicate the use of 450 nm (right between violet and blue).I still cannot find the specific wavelength used with LEP flashlights, I keep googling, not finding.
