lumen aeternum
- Joined
- Sep 29, 2012
- Messages
- 897
Link on that page for a module containing laser & wafer, just add power for $70Toys received in the mail: Transmissive White Phosphor Plates.
I confirmed them to be transmissive and to produce a very bright white appearing output. Great they used Sapphire for the wafer as it will conduct heat well when mounted to a heat sink. Maximum pump power from the laser is 7 watts per square mm.
These plates are very small, three sizes listed at the below link:
From smallest to largest:
1. Three mm diameter sapphire wafer with 1 mm phosphor spot (measured .65 mm spot) 5700K $30.00
2. Five mm diameter sapphire wafer with 1 mm spot (measured .65 mm spot) 6000K $30.00
3. Eight mm diameter sapphire wafer with 3 mm spot (measured 3 mm spot) 7000K $30.00
Excitation Wavelength 440-460nm Phosphor Dimensions (The yellow area) φ3mm/φ1mm Total Dimensions φ8*0.7mm/φ5*0.65mm/φ3*0.65mm Base Plate Material Sapphire Color Temperature 5700K / 6000K / 7000K Light Efficiency (Laser to White Light) 165lm/W@5500K Max Working Temperature 200℃ Max Laser Power Density 7W/mm^2
Thermal conductivity of Sapphire:
Nonmetals are often thought of as being relatively poor conductors of heat; however crystalline nonmetals can actually have very high thermal conductivities. The thermal conductivity of sapphire (aluminum oxide) actually exceeds that of very pure copper (RRR 500), from about 20K to 100K. Sapphire is used as an electrical insulator in heat sinking applications (magnet leads, for example) where excellent thermal conductivity and electrical isolation are required.
Note: 375 K is close to 100 C., 475 K is close to 200 C.
Supplier:
Shenzhen Guangchuangfeng Technology Co., Ltd.Contact Name: Sabrina Zhao
Registered company address: CN, Guangdong, Shenzhen, B1607, Rongde Times Square, Huaqiao New Village Community, Henggang Street, Longgang District Company Tel: 86-0755-13128736762
Company Email: [email protected]
White Laser Modlue Phosphpr Module Reflective Mode 400lm/500lm Laser Flashlight Laser Headlight - Buy White Laser,Modlue Laser Phosphpr,400ml/500lm Laser Flashlight Laser Headlight Product on Alibaba.com
www.alibaba.com
