Fires/explosions still are a very rare occurrence even if you count in user error. Which I don't, because IMHO it's your own fault if you handle potentially dangerous technology without educating yourself properly.
I understand the point you are making, but I do not agree. We know, for instance, that many airplane crashes are caused by pilot error. That does not mean we should not design pilot-proof systems.
Cell phones, tablets, laptop computers, and power tools all have built-in circuits to manage battery care. Unfortunately, flashlights do not. That is why I think there is a place for protected batteries in the flashlight world.
In my opinion, flashlights need to have the same battery-protection circuits as the other products mentioned above. Period.
I'll go further: Multi-battery flashlights should have full-on battery management systems, just like the rest of these devices. Each battery in a multi-battery device should have its voltage level independently monitored. Frankly, I think that the absence of such circuitry is a sign that the Li-ion flashlight industry is still in its infancy.
When all flashlights have low-voltage cutoff circuits, then we can talk about eliminating protected batteries.
Can you really say that your flashlight will never be accidentally activated (and over-discharged)? Can you say that you will never put a flashlight down, and forget that it is on?
I cannot.
I got surprised recently by one of the Nitecore flashlights I own. Like many recent Nitecore releases, my
Nitecore P36 has a significant standby drain. It uses the batteries even when the flashlight is off. I usually unscrew the tail cap to lock mine out, but this time, I forgot to do that. When I came back a couple of months later, I found that one of its batteries had been drained to 3.6 volts.
I learned something about my flashlight in this episode. For some reason the second battery in this 2x18650 model had not been depleted as much.
The
KeepPower 3400mAh batteries I use are a matched pair. They were purchased together, and they have always been used together. They are always charged together. Evidently, however, the standby drain does not discharge them at the same rate. Since these batteries only have a few cycles on them, I was surprised. Anyway, now I know about this, and I am keeping my eye on them.
And I am happy to report that these batteries are protected!
