Re: New Fenix PD32 2016
Also very cool and extraordinary:
When the
Turbo mode does the stepdown 3.0min after activation (from ~875 Fenix-lm down to ~385 Fenix-lm), the light in fact leaves the Turbo mode and enters the
High mode. In practice, that's the cool thing, one only needs to press the
side button 1x to get back to the
Turbo mode with 900 ANSI lumen (as long as the battery still has enough juice to deliver the necessary current!).
This feature is great because otherwise you'd land in the Moonlight mode after 'clicking 1x on the Turbo mode' because of the proper mode sequence Moonlight-Low-Medium-High-
Turbo-
Moonlight-etc. So you'd have to cycle thru all modes, i.e. click 5x to get back to Turbo and to reset the 3min-stepdown timer. That would be very inconvenient, if things were like that!
Only very few other lights have this '
mode down-stepping' feature (in contrast to the more common 'brightness down-steppping' within the same mode), too, where one could conveniently
step-up back with 1 single click.
The following graph, taken from
UPz's review, shows how the Turbo mode drops out of the Turbo mode after 3.0min and factually enters the High mode:
And same is true for the High-mode: When the
High mode does the stepdown 30min after activation (from ~385 Fenix-lm down to ~145 Fenix-lm), the light in fact leaves the High mode and enters the
Med mode. One only needs to press the
High mode with 400 ANSI lumen (as long as the battery still has enough juice to deliver the necessary current!).
And so on.
