7% Off For ALL LED Light Channels
ledbe
Vendor
The 7% off coupon code for LED Light Channels is available on ledbe.com,
input the code "LED-Channel" will get 7% off on the checkout page.
the code will expire on 31/12/2022.
you can use it to purchase any Aluminum LED Channels or Silicone Light Channels.
Link: https://www.ledbe.com/LED-Strip-Profiles
ledbe
Vendor
The 45° LED Alu Profile for corner applications, can light up the corners under the cabinets, closets, behind cabinets, etc. the 45 degrees light beam allows for light to be directed away from eyes. the standard length is 1M and the max length can do 6M, easy to cut to any length for your projects.
the inner width is 14.1mm and allows the max width of LED Strips is 14mm, recommend installing high-density COB LED Strips as the light source, no visible light dots and dark areas.
Link: https://www.ledbe.com/led-profile-alu
ledbe
Vendor
Recessed Tile Edge LED Profiles, which can be used for 10mm marble. the standard length is 1M and the max length can take 6M, you can cut to any length for your project. the Light Profiles are made of 6063-T5 aluminum alloy and with anodized surface treatment, anti-oxidation resistance and a longer lifespan than other similar products. the PC diffused cover for smooth light output. can be installed on walls, ceilings in the kitchen, living room, dining rooms, etc.
Link: https://www.ledbe.com/recessed-tile-edge-led-profile
ledbe
Vendor
The LED Linear Fixtures, max length is 6M and cuttable, comes with magnets, can insert the magnets into the slots and stick the Light Fixtures on the metal or magnetic wall, no need to drill holes or stick double-sided tapes, easy to install and use. there are various types of diffusers with different transmittance. recommend installing high-density chip-on-board COB LED Strips as the light source, the inner width is 15.2mm and allows the max width of LED Strips is 15mm.
Link: https://bit.ly/3XPyWFI
Features:
  • Model: ALP152
  • Material: Extruded Aluminum
  • Surface Treatment: Anodized
  • Colors: Silver(Default), Black, White
  • Size: 18.5*16mm(W*H)
  • Standard Length: 1M
  • Other Lengths Available: 1.5M, 2M, 2.5M And Max 6M
  • Custom Length Available: YES
  • Diffusers: PC Diffused Cover, PC Semi-clear Cover, PC Clear Cover, PC Frosted Cover, Prismatic Cover
  • Inner Width: 15.2mm
  • Max Width Of LED Strips: 15mm
  • Max Power: 18W/M
  • Beam Angle: 100°
  • Tolerance: ±1%
  • Magnets Included
  • End Caps With Wire Holes Included
  • Adjustable Brackets Sold Separately
  • 180°, 90°, 90° Vertical, 135° And 135° Vertical Connectors Sold Separately
  • Installation: Surface Mounted
  • Applications: Wall Or Ceiling Linear Lighting
  • 5 Years Warranty
Includes:
1*LED Linear Fixture
ABS End Caps With Wire Hole/Without Wire Hole
Magnets
