Aluminum LED Channels For Drywall
ledbe
Vendor
The Aluminum LED Channels for Drywall, which are made of 6063-T5 extruded aluminum material and anodized surface treatment, anti-oxidation resistance and a longer lifespan than other similar products. the standard length is 1M and max length can do 6M, can be cut to any length for your project.
the inner width is 10.5mm and allows the max width of LED Strips is 10mm, recommend installing the COB LED Strips to create a seamless line of lighting for indoor projects. there is only one type of diffuser available, the PC diffused cover, which is made of imported brand material, anti-yellowing, perfect light distribution and smooth light output.
How To Install:
Where you can order:
Link: https://www.ledbe.com/recessed-light-fixture-housing-for-drywall-use
