Drywall LED Channels For Interior Lighting Design
ledbe
Vendor
There are various models of LED Channels you can mount on the Drywall & Plasterboard & Sheetrock. lengths and colors are customizable. the diffuser is included, which is made of imported brand material, anti-yellowing, perfect light distribution and smooth light output. the Aluminum LED Channels are made of 6063-T5 extruded aluminum material and with anodized surface treatment, anti-oxidation resistance and a longer lifespan than other similar products.
Link: https://www.ledbe.com/LED-Strip-Profiles/led-drywall-extrusions
both sides with flange, the flanges with honeycomb holes, easy to mount on the corner of the drywall with screws, then plaster and painting to complete the installation. the inner width is 20.7mm and allows the max width of LED Stirps is 20mm, recommend the COB LED Strips, which are without any visible light dots and dark areas. there are 3 types of connectors are available, 90°,90° vertical and 180° straight connectors, you can use them to reconnect the LED Channels to a longer one for the interior linear lighting project.
ledbe
Vendor
The Recessed Drywall LED Housing for 12.5mm outside corner installation. the inner width is 5.5mm and allows the max width of LED Strips is 5mm, recommend installing the COB LED Strips, no visible light dots and dark areas. easily can be recessed into the walls, ceilings and tight spaces or corners to cast beautiful, diffused and even lighting throughout your space.
idleprocess
decamped
The products you're showcasing appear to be for new work - suspect the CPF market is going to be more about old work renovations.
KITROBASKIN
New Mexico, USA
Remodeling certainly applies here as well as new construction. Wondering when info will be supplied that allows a person to look more carefully and possibly order these products.
idleprocess
decamped
Sure. Just get the feeling that more minimal retrofit applications are apt to be more popular than parts designed to be sheetrocked-in.
ledbe
Vendor
These LED Profiles for 12.5mm inside the corner of the sheetrock, the standard length is 1M and max length can do 6M, can be cut to any length for your project. made of 6063-t5 extruded aluminum material and with anodized surface treatment, anti-oxidation resistance and a longer lifespan. the inner width is 5.5mm and allows the max width of LED Strips is 5mm, the Aluminum LED Profile can be worked as a heat sinker for better heat dissipation. comes with a PC diffused cover for smooth light output.
ledbe
Vendor
The LED Light Channel for the outside corner of drywall,
max length can do 6M and cuttable,
the inner width is 10.5mm and recommends installing the high-density COB LED Strips to create seamless linear lighting.
ledbe
Vendor
The Recessed Diffuser Profile with a long flange, can be recessed into the drywall for interior linear lighting projects. the max length can do 6M and cuttable, the inner width is 15.2mm and allows the max width of LED Strips is 15mm. recommend installing the high-density COB LED Strips as the light source. there is only one type of diffuser available, the PC diffused cover for the smooth light output.
ledbe
Vendor
Recessed LED Housing for drywall, the standard length is 1M and max length can do 6M, you can cut to any length for your project, the inner width is 10.5mm and allows the max width of LED Strips is 10mm, the PC diffused covers are included for the smooth light output. there are 3 types of connectors are available, 90°, 90° vertical and 180° connectors, easy to recess into the 12.5mm drywall for interior lighting projects.
ledbe
Vendor
The Aluminum Wall Skirting Profiles for 12.5mm drywall, you can install them as the skirting board lighting. the standard length is 1m and the max length can do 6M, you can cut to any length for your project. the PC diffused cover is included for the smooth light output. the inner width is 10.3mm and allows the max width of LED Strips is 10mm. recommend installing the COB LED Strips as a light source, no visible light dots and hot spots. there are 3 types of connectors available, you can use them to reconnect the LED Profiles together.
ledbe
Vendor
Check the Aluminium LED Channel for 1/2" sheetrocks, can be used for the wall washer lighting. the inner width is 10.3mm and allows the max width of LED Strips is 10mm, recommended use the high-density of COB LED Strips as the light source. there is only one type of diffuser available, the PC diffused cover for the smooth light output. there are 3 types of connectors available, you can use to reconnect them. the max length is 6M and cuttable. there are 3 colors available: silver, black and white.
Link: https://www.ledbe.com/wall-wash-recessed-lighting-channel-with-flange
ledbe
Vendor
The LED Lighting Channels for 1/2" Drywall, made of 6063-T5 extruded aluminum material and with anodized surface treatment, the standard length is 1M and max length can do 6M, the inner width is 10.3mm and allows the max width of LED Strips is 10mm, only PC diffused cover available for the smooth light output. there are 3 types of connectors available, 90°, 90° vertical and 180° connectors. you can use them to reconnect the LED Channels.
Link: https://www.ledbe.com/gypsum-recessed-lighting-channels-for-drywall
ledbe
Vendor
Flush Mounted Plasterboard LED Channels, the inner width is 10.5mm and allows the max width of LED Strips is 10mm, easy to install the high-density COB LED Strips inside to create seamless linear lighting for an interior lighting project, the standard length is 1m and max length can do 6m, you can cut to any length for your project. there are 3 colors available, the default color is white, you can take the silver and black colors too.
Link: https://www.ledbe.com/plasterboard-flush-mounted-aluminium-led-profile
ledbe
Vendor
1/2 Inch Wall Washer LED Light Channels, the max length can do 2M and cuttable, comes with PC Diffused Cover for the smooth light output. the flange with honeycomb holes design is easy to be recessed into the drywall. the inner width is 10.3mm and allows the max width of LED Strips is 10mm. you can use them for indirect lighting on walls or ceilings for indoor decoration.
ledbe
Vendor
Flush Mounted Plasterboard Aluminum LED Profiles, which can be recessed into the 12.5mm drywall, the standard length is 1M and max length can do 6M, cuttable and you can cut to any length, the inner width is 10.5mm and easy to install the Flexible LED Strips inside as the light source. the PC diffused covers are included for the smooth light output. you can use them for indoor linear lighting projects.
