- Joined
- Jul 15, 2021
- Messages
- 39
The LED strip diffusers are made of high-quality silicone material and are flexible and bendable. The standard length is 5 meters per roll, and the max length is 100 meters. You can cut them to any size for your project. It has a thin flange design and can be recessed into the slots on walls, ceilings, or the surface of lighting projects indoors and outdoors. They allow the different sizes of LED Strips from 3mm to 20mm. You can use them to design curve linear lighting projects.
Link: LED Strip Diffuser Covers
