- Joined
- Jul 15, 2021
- Messages
- 38
Mini size LED Channel without flange, can be surface mounted on the 12.5mm plasterboard. the standard length is 1M and the max length can do 6M, cuttable and you can cut to any length. 2 types of diffusers are available, PC diffused cover and a black PC cover for smooth light output. the end caps with wire holes and metal clips are included, easy to install them on the wall or ceiling. the Plasterboard Light Channels are non-waterproof, only recommend for indoor lighting projects.
Link: https://www.ledbe.com/mini-size-surface-mounted-plasterboard-led-channel
