Just FWIW, the Shimano wheelset on the Felt isn't flimsy, and they use good-quality spokes that very rarely break, not to mention easy-to-get axle/freehub parts. They can be used as a daily-driver wheelset if you want to. In point of fact, the Trek 1.2 uses cheap spokes which I'd rate for maybe 2 years of enthusiastic use before they begin to break, one by one, in the rear wheel (I currently work at a Trek dealership, but this malady isn't limited to Treks, of course).
The Felt's specs are nice (no surprise, it's a much more expensive bike) but pay attention to the fit, particularly the "drop" from seat level to handlebar level, when you test-ride the bikes. The Trek 1.2 will put your hands up closer to seat level in its default setup, if the photo of the Felt is representative of the actual item. Many riders, both first-timers and seasoned riders, prefer that more upright riding position.
Here's another riding tip: when you ride with one hand off the handlebars (eating an energy bar, drinking from a waterbottle), moving your remaining hand close to the center of the handlebar will reduce the "yaw" you'll exert on the handlebar if you hit bumps or dips, compared to
holding it at the brake lever ("on the hoods," where "hoods" are the rubber grip covers over the brake lever body). Some bikes are more relaxed than others, so this may not be too big a deal, but if you find the bike veering when you're riding one-handed, keep in mind the close-to-the-center technique
Obviously this puts your hands out of reach of the brake levers, so pick your times for one-handed riding wisely.
Another stabilization trick I use is to lay my knee against the side of the frame's top tube (while coasting, obviously). This gives me some triangulation for extra control, and I usually do this when I'm simultaneously braking with my right hand and signalling turns or lane changes with my left hand.
I ride in traffic all the time, so there's lots of opportunities for this knee-on-top-tube technique for the reason I named
but another reason to know it is
high-speed shimmy. Some bikes will hit a harmonic at certain speeds and conditions which causes the front end of the bike to shimmy violently. I had a bike which would do that at about 44mph (but only with the aero bar attached). Laying your knee firmly against the side of the top tube damps out the harmonic and almost always shuts off the shimmy. Hopefully you never have shimmy, but it's good to know what to do :thumbsup:
