Thanks, Kestrel
ssanasisredna, the problem is that you believe these things, concerning PWM rates above 17kHz, even though I am telling you in fact these PWM rates (17.5kHz specifically) caused me to get headaches and migraines. The effect is not instantaneous, but cummulative. There is nothing else in the environment modulating anything, and nothing else to mitigate the plain fact that this is so, and yet, you resist the notion based upon idk what you're talking about, these unreferenced "studies." "Not possible," you irrationally and quite frankly, incorrectly and wrongly believe these falsehoods, even though I am telling you honestly, first person experience here, not something I heard or read about, supposedly, but in fact me the man himself and a source of grievance concerning this menace of a technology telling you in fact PWM rates are indeed actually a real health issue for me and likely many others. "No," you're going to eventually reply. What's the smiley for this?
To avoid the PWM battle and get back on track...
what I have gleaned so far is that the issue is unlike the way the problem is solved with LED, using a constant current, because lamps are voltage controlled. Further, lamps are designed to be efficient and have the ideal color temperature at a certain voltage, and lower voltages will cause efficiency to drop (please confirm), and color temp to dip warmer and yellower. PWM with incan attempts to solve this, but in my experience, and documented elsewhere on CPF by others, there is still tint shift with incan PWM implementation.
Ignoring the efficiency and color temperature issues, if anyone has the patience or inclination, I would not mind a better understanding of how the current is controlled (or not) in a simple incan as the cell voltage drops. What exactly decides what the current is in an incan without a driver? I realize current and voltage are going to be related, but I don't have my head around it.
Lastly, if the efficiency and color temp issues could be ignored or tolerated, by what method could voltage be limited in a couple different stages without pulsing the filiment with PWM or something like PWM?
