It's an incredible light, though it can't take 14500 at all.
I love my mecarmy pt16, can't see a single AA beating that one
500 aye? How long?
The PR-1 stays at 420. No step down.
Selfbuilt also measured the SC5's turbo at higher than the manufacturer spec. It's an incredible light, though it can't take 14500 at all.
I really like the versatility of the 1xAA format and quality budget options. Small CR123A lights like the Olight S1 are impressive in their own way though.
Hey guys, is there any real advantage to using a AA battery flashlight apart from the availability of the battery?
They are certainly cool lights. But the 500 lumen claim is rather misleading.Zebralight SC5
Zebralight SC5w
Links only for proof of 500+ lumen specs on AA, these beauties live on backorder at the manufacturer, but are still in stock at some trusted resellers (such as Night Owl Gear <3 <3 <3 )
Eneloop AA FTW!!
As the drop lumens quickly and only attain 500 lumens for the ANSI FL1 rating. Don't get me wrong, still hugely impressive. But have a big step down to far more moderate levels.
L91 Energizer AA lithiums, if I remember right, have about 3000 mAh's so if you compare these to 1500 mAh CR123's Watt hrs. should be about the same (half the Voltage but double the Amp hrs. with the L91s). Still CR123's might have a small advantage in a single cell LED since they are closer to the drive Voltage of the LED, requiring less of a step up than a single AA.
I didn't say Zerbralight were misleading on their site. Just that in this thread claiming it as a 500 lm light is a little misleading.
That said, it is clearly engineered to give a higher headline figure. Nothing wrong with that, lots of companies do it.
And 300 lm is still impressive for an AA. But the Zebralight is somewhat of a rarity in the market place and you most certainly pay for the privilege.
To each their own, I guess. I don't see a 3 minute stepdown as an issue when discussing max lumen output, especially not when we tolerate significantly shorter bursts from modded flashlights.
Anyway, back on topic: Do you guys prefer longer but slimmer AA lights or shorter but wider CR123A lights for pocket carry? I have a small extra pocket that can accommodate either, but I like the shortness of CR123A so that it doesn't interfere with the next pocket. For normal pocket carry, I think I prefer AA because of Eneloops.
Having said that, for applications where rechargeable cells will work (the majority of my use-cases), Eneloop AAs are still my favorite battery for the safety factor. Versus li-ion cells, I don't need to hover around Eneloops while they charge, I don't need to worry (much) about over discharge, and someone else in my family can put them into ANY device and nothing bad will happen. I've stayed away from 14500s for this reason -- but if I didn't have to worry about the safety/mistakes of others, and if I was into chasing lumens, I would probably prefer 14500s to 16340s for the capacity difference, and for the ability (of most AA-sized lights) to use a wider variety of chemistries.
I sort of discredit any light much bigger than the battery itself in regards to lumen output... Like the SC5 is massive for a AA/14500 light.
http://www.candlepowerforums.com/vb...L2)-Review-RUNTIMES-BEAMSHOTS-VIDEO-and-more!Perhaps a member with a nice AA collection can post a family portrait?
fwiw, the L11c is 29gFrom left to right:
Panasonic Eneloop Pro AA NiMH; Zebralight SC5, SC52, SC51; L3 Illumination L10; Skilhunt DS15; Olight S15; Thrunite Archer 1A V2.
Zebralight SC5: Weight 58.3g, Length 81.5mm, Width (bezel): 22.6mm, Width (max) 27.0mm
L3 Illumination L10: Weight: 20.7g, Length: 79.4mm, Width (bezel): 17.1mm
:thinking:
Here I was under the impression it was among the smallest AA lights. Perhaps a member with a nice AA collection can post a family portrait?
