Sold/Expired Custom & Modified Super Bulbs
cbsmith111
Yes I'm aware that I'm already at about the max output for potted bulbs. I just thought it would be interesting to compare them or have alternatives.
cbsmith111
What about the potted frosted carly 1499? That sounds like it could be neat to try. Would the dimensions work at all with a bifocal reflector?
Conte
It should, it's a tiny bulb, and I would assume it's potted in such a way to have correct filament hight.
I rigged one up in a mag wi th a bi focal before. Worked really well.
You just have to be careful with your battery voltage.
A freshly charged set of large IMR's will pop it.
I ran it with 18650 LiCo's charged on a charger I calibrated to cut off at 4.17v.
double0thirteen
Payment sent - Unique Transaction ID: 8LA46817T0625862Y
1x Bi-pin WA01274-U (7.2V, 2.77A) $10 Each (30 AVAILABLE) (Use 6 Eneloop or 2 IMR)
1x Bi-pin WA01331-U (9.6V, 2A) $10 Each (15 AVAILABLE) (Use 9 Eneloop or 3 protected)
1x Bi-pin WA01079-U $10 Each (2 AVAILABLE)
1x G4 Bi-pin FM (14.4V, 3.A) $12 Each (8 AVAILABLE) (Use 11 Eneloop or 4 protected)
1x G4 Bi-pin FM Axial (6.6V, 3.3A) $12 Each (15 AVAILABLE) (Use 7 Eneloop or 2 IMR)
1x G2 Bi-pin FM1794 (7V 3A) $10 Each (4 AVAILABLE) (Use 2 protected)
1x Potted Carley 1057 (6V 1.7A) $12 Each (1 AVAILABLE) (Use 6 Eneloop or 2 protected)
2x Ultra Stinger nonmodified (6V, 1.8A) $6 Each (20 AVAILABLE) (Use 5 Eneloop or 2 protected)
1x 3854 Pack of HO (6V, 4A) & LO (6.V, 1.9A) $10 Pack (5 AVAILABLE) (Use 6 Eneloop or 2 protected 18650)
1x 3853 Pack of HO (7.2V, 3.3A) & LO (7.2.V, 1.5A) $10 Pack (5 AVAILABLE) (Use 7 Eneloop or 2 large IMR)
$108 + $5 shipping = $113
double0thirteen
Payment sent
Transaction ID: 3WH359518S9589405
2 x G4 Bi-pin FM Axial (4V, 3.3A): $24
2 x G4 Bi-pin FM Axial (6.6V, 3.3A): $24
2 x G6.35 Replacement Socket: $48
shipping: $18
Total: 114
ma tumba
Russia
The reason I wanted to extract pottet 1499 was because your frosted version are only potted ones also. And I like frosted bulbs very much. So can I extract them if I want?
breadfan
#62 G6.35 socket $24
1x Boro lens $7.50
Shipping $6
:paypal:
python
São Paulo
I have the FM Bin Pin
For the 2 x 18650, do you have any suggestions for these bulbs?
Runtime and Lumens?
Regards
ma tumba
Russia
FM, I am currently using a 6.6 axial bulb with a PHD-M6 pack set at 6.8V. At this voltage the bulb looks significantly underdrived, compared to 1111. The next available voltage with my pack is 7.5V, do you think it is safe for the 6.6V bulb to try?
BTW, the beam created by the axial bulb in the M6 is fantastic, by far the best one I've seen.
breadfan
G4 Bi-pin FM Axial (6.6V, 3.3A).....(Use 7 Eneloop or 2 IMR)
7 eneloop would be 8.4v nominal, 9.8 hot off charger. I'm running it on ~ 8v (2 samsung INR18650- they murder 5761's and m@gchrger bulbs even rested) and it STILL looks like it could take more.
You should be just fine.
Conte
Pretty sure I've dialed my JM-PH-D1 to at least 8v with that bulb.
It can take a pair of 26650 IMR'S full balls with a FET switch no problem.
vestureofblood
Missouri
Hey FM,
I have some bulb related questions. I mangaed to pick up one of your E2e Bipin sockets, which is ALMOST as cool as my E2 Fire. The problem I am having is that all the bulbs I currently have are too long for the E2 socket. I was able to get the 1499 to work by shimming it, but then the head does not screw down.
In the Bi pin thread it says that the bulbs for that are
Strion
TL-3
Axial
Will these bulbs fit and focus without shims? What is the Axial bulb?
EDIT: Also would that ultra stinger bulb work for either the E2e socket or the E2 Fire?
Thanks
fivemega
California
Your E2e socket was designed to use with Strion bulb for single Li-ion and TL-3 bulb for 2 Li-ion in E bodies. Both bulbs have similar LCL (Distance from center of filament to bottom of bulb glass) and will properly focus with E head without needs of washer.
Stinger and super stinger also have very similar LCL but voltages are designed for Ni-Cad or Ni-MH which are not CPF favorite. Stinger bulb is designed for 3 NiCad and will underdrive with single Li-ion and Super Stinger bulb is designed for 5 NiCad and may flash with 2 Li-ion.
When using Stinger bulb, I suggest
these bodies powered by single IMR 26650
22 watt custom Axial bulb was designed to work with 3 Li-ion in
these flashlight but will fit in E head if you have 3 cell E body.
Since CL1499 and custom made FM1794 bulbs have higher LCL and won't fit or focus in standard E heads, I designed
E2 Mini Turbo Head to boost up your E flashlight up to 1000 lumens and throw much longer.
I hope you find this helpful.
:thumbsup:
vestureofblood
Missouri
Hi FM,
I was wandering if perhaps you can explain something to me. Is there any designation in a set of numbers on light bulbs that gives an indication of the actual size of the bulb itself? What I mean is, both a wa1111 and a philips 5764 are G4 bulbs, and are no where near the same size. I have also seen additional sets of numbers given for some bulbs such as T2.75 G4. Is that to do with bulb size or something else?
Thanks
naked2
Upland, CA
WA 1111 is made by Welch Allyn; 1111 is their stock number. Same thing with Phillips, I believe.
vestureofblood
Missouri
Ok, after searching diligently yet again I was able to find an answer to this question. Finding a source for the explanation of G4 G5 etc was easy. Finding useful information about the rest was not. The G4 is the space from center to center of the pins (4mm in this case) The T is the shape of the glass (tubular) and the rest of the number is diameter of the globe (not the base) multiplied by 1/8" or .125. So a WA1111 bulb would be G4 T2.25
Thanks again for offering these increasingly rare bulbs FM.
Swagg
Is the FM1794 still around for purchase? Where do I find it?
