weez82
If anyone gets this light please post beam shots. I'm very interested in this light but I need to see it in action before I know if its what I want. Thank you
The original MiNis were a mixed bag - especially the CR123. I have an aluminum NW AA MiNi than is an awesome light. I have gifted several other AA MiNis that were rock-solid. On the other hand, I had a AA Ti MiNi that ground and cross-threaded and a CR123 aluminum MiNi that had such loose threads that I could not predictably change modes on it.Sorry guy - wasn't trying to be personal or insulting. If you are as old as some of us around here shaky hands just come with the numbers. And I learned long ago there are fairly big differences in different peoples manual dexterity - not an insult - just a fact and I was thinking out loud an explanation for why one person was reporting issues with cross threading.
Is this actually true? I can find a number of pages announcing a strategic partnership almost six years ago, and David Chow becoming chairman for Olight, but nothing recent that confirms this is still the case today.Probably, since David owns both companies.
Oddly, it did not step down after 15 seconds. It was getting warm at 30 or so, and was still manageable at 1 minute, though possibly getting a bit dimmer? If they do have a timed ramp-down, then it is very gradual.
Got mine as well!
Looks good--the moonlight mode is genuine moonlight. The high is very high--I don't have any way of getting exact numbers, but I compared it to a ZL H52w running a 14500 on high, so about 500 lumens, and it was very plausibly twice as bright as that, when measured by ceiling-bounce.
The optic gives it a very large and uniform hot-spot with a much dimmer spill. Not my favorite beam profile--I prefer reflector beams--but a good one of its kind.
Anyhow--all in all, at a first glance, I'd say it behaves as advertised. Cute, tiny, and very very bright. A good refresh of the Mini line.
...If these honestly aren't stepping down after 15 seconds I think I'd consider manually dropping it down a step. At least I think that much heat for any extended times might be shortening the life of the LED unless it's really well heat sinked (which would seem difficult to do in such a tiny light....
That's fantastic information! Could someone kindly post a video of the beam shots? Would love to see how the flood is on this light.
This looks like a neat little light - something I'm interested in, but I can't help thinking that I'd prefer a medium mode that is 100 lumens or 150, so the runtime on medium would be significantly longer and there would be a more noticeable difference between the medium and high output levels.
A neutral version would increase my interest, if it proves to be a reliable light. I'm happy to see another tiny R/CR123 light appearing on the scene.
Strongly agree. I'd also like to see a mode-selection layout that does not require you to go through medium and high before you get to moonlight!!
I think this is going to be a common sentiment, seems a bit crazy, especially since it runs on a low capacity RCR123A. I wonder what the numbers are for a regular CR123A primary cell, maybe that is more reasonable. Or it could be they thought; well it's rechargeable so don't worry about the runtime on Medium.Yep- a medium mode between 70 to 100 lumens would have been nice for good runtime.
