PoliceScannerMan
It always happens, but if one day you do not take them with you, you will definitely need them.))))
I still bring them LOL
I think I've read somewhere stepping down every two levels means consuming 50% less power.
2.25 to be exact. Just a little over double.
I didn't think I'd ever say this, but I'm slowly coming around to the idea of purchasing a rotary style HDS, actually if I do it would most likely be the EDC Tactical.
However the biggest blocker holding me back is that the rubber boots can't be replaced like on my clickies.
I remember I previously read that the HDS lights are going to have a major redesign sometime in the not so distant future and this will then allow you to be able to swap the rotary/clicky bodies, but I haven't read anything about the actual rotary design being worked on. Anyone remember if Hogo mentioned anything about this?
I would really require the the rotary light to be field maintainable before I buy one (or more).
I didn't think I'd ever say this, but I'm slowly coming around to the idea of purchasing a rotary style HDS, actually if I do it would most likely be the EDC Tactical....
The only truly worn out buttons I have seen are flush buttons and it is where the person uses their fingernail to push the button... a good hard thumbnail can start cutting into the rubber. I think we had 2 cases like this.
Couple of myths. A mechanical switch is more reliable than an electronic switch. Nope. Not even close. Current electronic switch in the HDS is rated at 1,000,000 clicks. That is 278 clicks a day for 10 years.... or 28 clicks a day for 100 years.
You click more with a... Clicky than you do with a Rotary.
HDS time is very much like geological time. What is quick or soon in geological time is several lifetimes in human time. HDS is very similar.
Henry and I have spoken a lot about a new model to replace the current model. It is all talk... BUT... if the Clicky does not go extinct, it won't be user serviceable as far as the button like the current model, and the new model will most likely NOT be interchangeable with the current models... Let the bitching begin.
[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]I understand you may be [FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]referencing[/FONT] between the HDS Clicky and HDS Rotary, but Surefire's Z41 tailcaps are magnitudes more robust and reliable than any electronic switch found in any HDS light. And the physics of how they work and function, with their simplistic and fail proof design, would disprove any conjecture about HDS's electronic switches being more reliable than any other switch.
[/FONT]
I understand you may be referencing between the HDS Clicky and HDS Rotary, but Surefire's Z41 tailcaps are magnitudes more robust and reliable than any electronic switch found in any HDS light. And the physics of how they work and function, with their simplistic and fail proof design, would disprove any conjecture about HDS's electronic switches being more reliable than any other switch.
