Dale over on BLF modded his E07 to produce over 10,000 lumens.
The mods he did to it didn't sound that hard to do and sound fairly simple. While the mods he did are not quite beginner level, they are far from advanced. He did the following:
1. Emitter-swapped to LH351D
2. Removed the tailcap PCB and spring and replaced with solid copper sheet and a copper post.
3. Removed the star, chamfered the bottom edges and replaced it into position with a proper amount of thermal grease.
... and that's about it. Do those and your E07 should produce 10k lumens. If I were doing those mods to mine I figure the emitter swap would take 20 minutes, chamfering the bottom edges of the star would take 30 minutes, and replacing the tailcap PCB with copper shouldn't take more than 1 hour. Overall fairly straightforward mods. The hardest part would be waiting for the LH351D emitters to arrive.
