Thanks for your input.
I'm using a brand new head and like new older style (with knurling) MD2. I've cleaned everything with isopropyl alcohol and even though it wasn't needed, I polished the aluminium contact surface lightly on cloth held tightly to a board with some gentle polishing compound.
Every now and then I was getting a moonlight low or full low that was unstable and with a bit of flicker. I also had the low flickering like a candle on low if I kept rotating the head towards off.
The flaky low operation seems to have gone now, and the candle like flickering while continuing to rotate towards off is very minimal now.
My only thought is that the mechanical action of the spring loaded pin and resistor has worn in a bit more?
I usually have white or blue plumbers tape handy, I've currently been using white. I'm not sure what the difference between the two is, but the white stuff I'm currently using is very thin.
Initially I used a length that I folded length wise (a bit fiddly but can be done) so it's slightly less wider than the threads. I wrapped twice under mild pressure (four wraps worth as it's folded over).
This worked great initially, started out a bit tight but worked in perfectly. I kept taking the head off to see how it was handling and noticed it was wearing fast but not migrating into the o-ring of contact area which was good.
Everything had been cleaned and lubricated before applying the tape.
I wrapped again using a longer laterally folded piece of tape and did about six wraps, twelve wraps worth of thickness. I cut the tape after completing the last full wrap rather than pull it tight and snap it off.
This application has settled in great and looks fine even after a bit of use and quite a few head removals.
I'll be sticking with the tape application with this light, it's working for me.
It's interesting, to me anyway, that others have been using tape on their lights.
Now that I've got my long story about plumbers tape out of the way, I took the light to the beach this evening. It was pretty hazy but I got to stretch its legs a bit.
I like the beam, even at reasonably short range there's still plenty of size to the spot and I find there's a good amount of spill for general surroundings.
Given more range and the spot is able to light up large areas with quite a bit of light.
There's no tunnel vision with this light, within consideration of being a thrower. A nice large spot with plenty of spill.
