raggie33
*the raggedier*
- Joined
- Aug 11, 2003
- Messages
- 13,564
i have 2 12 volt batterys in parallel . there like 100 amp hour per battery so 200 combined.. how many kwh hours should i get i have them ran into a inverter for ac 120 volt
+12V • (2 • 100AH) = 2400Wh DC
You'll lose energy in the conversion and higher draws will decrease efficiency in the batteries and inverter alike, dependent on the specifics of the components.
+think i got only 1.4 kwh but thats not bad for a 1000 dollar solar eray
+my system is panels to controler then to 2 x 12 batts then interor to a sine ac device
Spend the $ on Lithium-Iron-Phosphate batteries. They have almost double the usable capacity of Lead-Acid or Nickel-Metal-Hydride. They have more usable capacity than Lithium-Ion.i have 2 12 volt batterys in parallel . there like 100 amp hour per battery so 200 combined.. how many kwh hours should i get i have them ran into a inverter for ac 120 volt
+Spend the $ on Lithium-Iron-Phosphate batteries. They have almost double the usable capacity of Lead-Acid or Nickel-Metal-Hydride. They have more usable capacity than Lithium-Ion.
So if you have 200 Amp-Hours of Lead-Acid you can use 100 Amp-Hours (more or less) of LiFePo4 because "deep cycle" Lead-Acid batteries get damaged when drawn down more than 50%. Nickel-Cadmium, Nickel-Metal-Hydride, and Lithium-Ion all have lower charge limits that drawing below will damage them.
LiFePo4 can be drawn down to almost zero. It also tolerates being charged to 100% and being held there long term. These batteries have become very popular with RVers because they can opt to cut a lot of weight for their solar system storage at the same capacity, or add capacity with less weight reduction by replacing each old battery with a higher Amp-Hour battery or adding more batteries if the vehicle has room.
Now...if he only had a flux capacitor...and 1.21 gigawatts...and a DeLorean...+
LFP batteries are two things, incredible on performance & longevity and expensive.
________________________________________________________________________________________________________________________
raggie, if you get into your solar charging more, very much consider going 24V and wiring your stuff in series.
Less overall wiring & just alot easier to get all your watts.
1.21 gigawatts should do.
Why? Is there a problem with the gravity?Great Scott! This is heavy.
Both in terms of number of cycles and calendar life. Prices are starting to fall under $100/kW-hr for new cells, less if you're capable of making your own battery using cells from battery salvage places. Many times you can get cells which are practically new at bargain prices.+
