The high CRI wasn't enough for me. I replaced it with the SC5w II and I can't tell a difference in CRI. I do like the 4500K instead of 4000K.
Great, and I ordered the 4000k high cri just this moring.
I think the negative feedback early on definitely hurt this light's reputation (at least on C.P.F.) It's a shame because it's VERY well constructed and feels great in the hand. However, it's a light advertised to have a "top level" tint, so you would think Zebralight might have inspected the quality BEFORE shipping.
It would be even sweeter if ZL offered an optional tailcap with strong magnet.
And a flanged bezel ring with a lip that covers the edge of the head.
However a few days of use, its gone from an instant like to a love. My next ZL will have a bigger tank(18650) , maybe an xhp50 in the sc600Fd mk III which would suit me well.
Its not often i take a light in work and use it, then bring it home to use.................then back in work next day for use and home again!
:laughing: It may be too late emarkd Just pondering over my next one, maybe just get a couple, xhp35 neutral and xhp50 . Love your collection by the way , awesome!
Yes, will i am looking at the sc600fd mkIII as the floody beam suits my general uses(home or work). Just hope i can get hold of one UK side rather than order from ZL. However if it comes to that i will do.
Used the xp-l2 easywhite last night a bit, although it is not my preferred tint(yellow side), in use its not much of an issue. Just takes a little getting used to from almost perfect white 4500k 219b's or the slightly rosy 219b's. I am one for having a little variety, i dont want all my lights to be the same. For example my xpl HI go from 4000k+, as with my nichia's 4000k-5700k . My sweet spot seems to be 4000-5000k.
From Zebralight's website: Automatic stepping down from High to Medium, and from Medium to Low when battery capacity is low3. Wait a few minutes: the flashlight switches gradually to level M and finally L (firefly mode)
From Zebralight's website: Low battery alert when the light is switched OFF (LED flashes if the battery voltage is below ~1.06V)5. My flashlight does not turn off, but switches in beacon mode (one flash every 4-5 seconds)
I think that is how the flashlight is supposed to behave when a cell that has a low voltage is inserted. I, too, find it somewhat annoying and would prefer if the low battery alert was limited to 30 seconds after the light is switched off. I would not call it a problem though - the alert is there for a reason and it is quite obvious what you have to do to make it go away :laughing:6. If you want to turn off the flashlight, you must: wait for it to turn off spontaneously, or unscrew the tailcap. Strange and very annoying!
Do you also have this problem?
1. Insert a low cell (below 1.2V, for example);
No. I do not try to make a drained battery perform as if it was full, over and over again. This is quite bad for the battery.
Charge your battery! STOP trying to make it produce high mode over and over, when it is drained.
IF Zebralight had given you a LiIon option, and you followed the same misbehavior of repeatedly firing High mode with a drained battery, then the LiIon could potentially erupt in flames the next time you try to charge it.
Fortunately for people who don't understand, yet, that a depleted battery should NOT be repeatedly fired at High mode, the new Zebras don't work with LiIon. So the only damage is that you are destroying your Eneloop, but it won't FlameON!
Thank you for the reply.
Step 3 is perfectly normal, I know the Zebra interface .
The real problem is point 6. OK, you're warning me that the battery is low. But why can not I turn off the flashlight by simply pressing the button? If I do not want to see the flashes again, I have to wait or unscrew the tailcap ... this is illogical.
