Re: Jetbeam RRT-01 vs Sunwayman V11R (1xCR123A/RCR) Head-to-head Comparison Mini-Rev
Are all of these lights here magnetic rotary brightness controlled lights? Can you name them from left to right? Thanks!
yes they are all magnetic rotary
I do not know what the one on the left is, it resembles a
Niteye 15, but the tail and body is not the same, possibly a Lego with something, not sure what.
the light on the far right is a
Niteye 10. Niteye 10 and Niteye 15 are magnetic rotary, but have iirc 11 added detents in the ring, it is not continuously smooth ramping. (fwiw, HDS is also not continuously smooth, it uses 24 steps, each 1.5x brighter)
from left #2 is the Jetbeam RRT-01 with the McGizmo clip clone, those have a smooth reflector, and totally smooth ramping, that I absolutely Love!
#3 is the RRT-01 I have, it has the shorter clip, and an Orange Peel reflector, also with smooth ramping
#4 and #5 are Titanium versions of the Jetbeam RRT-01, the Jetbeam TCR1, these are smooth ramping like the RRT-01, and no tail switch.
There is also a Titanium version of the V11R, called
Sunwayman V10R Ti(tail clicky and smooth dial)
Some people like that Sunwayman versions with a tail switch have no parasitic drain, and can use "memory". iow, with the Sunwayman, including the V11R and V11R Ti, you can set the dial to a brightness you like, and then switch on and off at that same level. (if the dial has not accidentally been moved)
The RRT-01 and Niteye 10 and Niteye 15 do not have tailswitches. The lights turn off by ramping all the way down. There is parasitic drain. The Sunwayman models have no parasitic drain once you click the tail switch off. The Sunwayman lowest level is not as low as the RRT-01 which goes to 0.015. Ive read that the Sunwayman low is 1 lumen, but I have not confirmed that.
The Niteye, Sunwayman and Jetbeam use Cool White XM-L2 leds (earlier models had XM-L). I tried a V11R that was modded to 3000k N219c. I loved the tint, but the Vf of the LED screwed up the ramping so that the light would drift more after letting go of the dial than with the stock LED. I do not therefore, recommend swapping LEDs.
Here is the sunwayman drift with an N219c 3000k.. It changes to almost 100% brighter based on which way it it facing, basically it responds with excessive sensitivity to the earths magnetic field, IF you swap the LED.
I tested my RRT-01 the same way and its brightness only changed about 10% when changing which way it is facing.. pics of that in post#10.
fwiw, most people, myself included, cannot detect a change of 10% brightness, it takes a change of at least 50% be be slightly noticeable. I do not think you will have a problem with the V11R drifting if you dont swap the LED. I prefer the simplicity of the RRT-01, just turn the dial. With the V11R you have to click the tail, then change grip and turn the control ring.
another difference is that the RRT-01 is 18350 compatible, the V11R with an AA extender can be AA compatible.
When using 16340 in the RRT-01, there is room for a cash stash (and prevents battery rattle):
and fwiw, the Oveready 18350 battery carrier also fits a cash stash, and will prevent rattling:
