Hi guys,
Wrists are doing much better, thanks for the advice. Been taking it very easy on them and I'm back at full capacity now.
Until this point it's been easiest to do all the pieces in a single operation and work my way through the steps assembly-line style. I'm at the point now though where each individual piece needs tested and matched with all its other pieces so from here out it's individual assembly.
Something I've been having issues with is the PCB insertion. The circuit is friction-fit into the body so it needs slipped over a tiny ledge inside to hold it securely in place. This requires a fair amount of very evenly distributed force. I've machined a tiny Delrin piston to cradle the board and keep it flat as it's inserted, but actually applying force has been problematic.
Fingers are certainly no match for the task:
And while a hammer works sometimes, it generates a TON of energy that often makes the LED wires crooked or jars the pieces out of proper alignment. Not very reliable (or civilized).
What I need is a very slow, steady pressure that I can direct into the assembly to finish the last 1/8" of travel. The assembly I built to do this turned out so ridiculous that I just had to share it with you. :laughing:
Haven't had a chance to take it on the maiden voyage yet but I'm certain it's exactly what I need. Stay tuned as we enter the final stretch of this run!
