PhotonFanatic said:highorder,
Can you suggest a few vendors? Thanks.
We used to make our own arbors out of aluminum rod. Turn down the outside diameter to the size of the diameter (inside) of the piece you are going to hold. Drill and tap one end of the arbor, some thing fairly large. put a large countersink on the end, cut slots 90 degrees through the threaded end, go past the end of the hole a little bit. put the same countersink angle on the inside part of a bolt, screw or whatever has the same thead as the hole you made. when you tighten down the bolt it will expand the abor and hold the work in place.
I just got an ENCO catalog - the have them listed in standard sizes - 1/4" and up. another tool place is MSC industrial.
