) How would you prefer to purchase the light?
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
Up to $200.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AA sized cells common to most stores. I have a bunch of rechargeable AA cells.
I don't care - I have a good standalone battery charger.
I want an indoor "blackout" light (15-50 lumens)
Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
5-20 yards/meters (check out a noise in the backyard)
30-60 minutes (I have plenty of batteries just ready to be changed)
Very Important (Camping, Backpacking, Car Glove-box).
I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
I want a body mounted switch (near the head, like on a Maglite).
A simple on-off with only one output level is fine for me.
I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
15) Water resistance
IPX4 (Splash resistant)
16) Storage conditions
In house (temperature/climate controlled environment)
This is for a person with severe hand problems due to arthritis. A 2AA-sized body fits well along with an easy to use side button.
Up to $200.
3) Format:
4) Size:
6) Manufacturer:
