The_virus
Yeah I think the main problem is that many stores will carry stuff you can use, but under different names. Food grade silicone grease, diver's regulator grease, etc.
I went searching yesterday and I found Silicone Lube at Canadian Tire in the automotive section, but it was a spray. I used to work at CT and they did carry the grease in plumbing (I was a hardware dept. guy) but it seems like it's gone! All they had was this mysterious container of "Plumber's grease" which could very well have been silicone but the packaging said absolutely nothing about what it was made from. I didn't want to chance it, so I went to Rona and asked there too.
The guys at Rona recommended some sprays, but I insisted on a grease (they didn't seem to understand that spraying a flashlight could get quite messy, especially for such a delicate and precise application). They ended up recommending "White grease" which they said would lube and be o-ring friendly. The tube says it is sulphonate-based and is good for a wide variety of applications to prevent water and grit entry.
I mentioned Lithium grease before and it seems very similar. One appealing thing about white grease is that it's so easy to find. Canadian Tire actually had tons in automotive, in tubs a little smaller than a margarine container. The older guy at Rona who took over after the younger guy was recommending a spray said that white grease would be "definitely o-ring friendly".
I think I'll head to Home Depot where Pydpiper said he found silicone grease (I'm still annoyed that Canadian Tire appears to have stopped carrying the stuff I personally used to sell to customers). While I'm there I'll ask about white grease being o-ring friendly as a cross-reference or second opinion. I'll update this post with what they say.
