Vinh, will an XPL or xml2 dedome be going out for testing? It's not really a question of whether I'm getting this light, just a question of which option.
Sure when I have a XPL PDTc version made. As of now I don't have enough PDTc.
mee too xpg2 dedome budget version! !Got one for you
Edit: NM Preorder only. I need both my samples for other tests
I suspect Vinh is going to have to raise the price on his XPG2 dedome.
$180 is actually $8 cheaper than the stock unmodified XPG2 dedome from International Outdoors or Mountain.
OK Vinh, I have decided to get one, but want one in either the XPG2 S3 3D or Nichia 219b. Can you get either one of these?
Emailing youYes I can
Curious to see if you decided between the two, and why.OK Vinh, I have decided to get one, but want one in either the XPG2 S3 3D or Nichia 219b. Can you get either one of these?
I have a stock TN36. When I switch it on in Turbo after 15 minutes in tailstand the head of the lamp has 70°C.
My MM15 after the same test has 62°C.
It is not so easy to switch it off without gloves.
Up to now I'm not sure if I should make this test with the Meteor or not..
Hi Vinh,
Any chance that you could make a 50/50 - six XPG2 S3 3D And six Nichia 219b?
How much would that be?
Thanks,
-Chuck
I decided on the xpg2 s3 3d dome on model. Just judging from the beamshots above, the nichia looks a little too brown for me. And if what I read is true- 3d tint is better than the 3c and the m43 will ship with 3d-, then I think I'll be happy with that especially considering the output vs price vs heat difference. I think (just a hunch) running each version of the light on a setting of equivalent brightness-xpg2 dome on vs 219b-, the nichia will produce more heat and use more juice. Not to mention it's $30 more.Curious to see if you decided between the two, and why.
I decided on the xpg2 s3 3d dome on model...
Vinh, are you only getting the dark grey version or are you getting some light grey ones as well?
I think you are fine to run your test. As I said in an earlier post my XP-G2 version never exceeded 53C, but ambient was also 24C. I am not suggesting that you run it for 15 minutes like you did your TN36 though, but thermal regulation should prevent it from ever reaching anything close to that anyway. What cells were you using in your TN36?
