Manker E14 (4*Cree XP-G2/ Nichia 219B) is releasing
Theodore41
Athens Greece
I do like little power house EDC lights, nice sometimes to have a bit extra on tap!, this seems to have it all!!! :cool:]
Not sure its safe to run a cr123 in it though due to the higher Amp ask! Would have thought IMR/INR only...............
If you read the thread in BLF,you see that if you put the 18650 tube from the S1,it fits.:)
Wendee
Ontario, Canada
:D It's now on Amazon.com.
Can you tell us the different lumen output levels, run times, if it has over discharge protection and if it has step-down when the battery gets low? Actually, sorry for asking so many questions. Maybe it's easier to let us know when this information will be on your website?
I'm very interested in the 4xNichia model and looking forward to learning more
I can't find any answers to the questions I asked in this thread & all I see on the Manker website (& Amazon) is "Max Output: XP-G2 1600lumens / Nichia 219B 1400lumens".
I see a lot of posts mentioning desired material in the future (brass/copper/titanium) and 18650 battery stuff, but most people don't seem to wonder about the basic specs for the flashlight that actually exists. This confuses me. :thinking:
Maybe it's just me, being new and all. :shrug:
I guess I'll have to wait for a CPF review of this flashlight to find out the specs. Oh well.
Phlogiston
Scotland
Most people here are probably projecting a rough spec by analogy to the BLF A6, because Manker are using the same driver circuit.
To give you a general idea, my BLF A6 has roughly the following levels for its seven output levels: 1lm, 10lm, 70lm, 200lm, 450lm, 850lm and 1300lm. You'll note that the maximum is pretty similar; the other levels are very likely to be similar as well.
Given that each and every light will be slightly different because of manufacturing tolerances, the output differences between the BLF A6 and the Manker E14 with Nichia 219Bs will probably fall within the margin of error. The E14 with XPG2s will most likely be a fraction brighter at each level, but even then, I'd be surprised if the differences were hugely noticeable by eye.
Wendee
Ontario, Canada
Thank you Phlogiston.
Now I understand. I appreciate you taking the time to explain this to me (I'm still learning the basics). That was very nice of you. :)
I'm disappointed that Manker choses to talk about their other models (Timeback) rather than answer questions about the E14.
It seems that we're expected to "figure it out" ourselves by researching the driver? And even then, we can't be 100% certain?
Why won't Manker post the specs themselves? Why won't they put them in writing?
The fact that they won't, even after being asked to, doesn't leave me with a comfortable feeling (at all).
It sure looks like a nice flashlight though. Maybe someday I'll feel comfortable enough to buy one, but now I'll definitely wait until I see some reviews and hear feedback from people who have received the light.
giorgoskok
The driver it uses it isn't like the regular linear drivers you know (8x7135 for example) .
It uses a fet , max current is not regulated , it can be 5 amps , or even 10 . (It depends on a lot of factors , and the main one , the battery)
For more info , you will have to wait for a review as you can understand from the replies on this thread .
recDNA
Will it damage an AW IMR16340 or Efest IMR16340? Neither can handle that kind of amp draw... Or is the draw somehow diminished with lower output battery like 16340? Now I'm nervous about using it.
Wendee
Ontario, Canada
I guess I'm used to seeing flashlight specs from companies and they add at the bottom "results from using xxxx battery" etc.
Can't Manker do the same?
How can anyone do a review and say that the flashlight works as the company claims it should? There are no statistics to compare it to.
What if someone tests it and it runs at 1400 lumens (as described for the nichia) but only for 5 seconds? Since Manker hasn't provided a step down time (or if it has step down?), I guess no one would be able to say anything because it did in fact put out 1400 lumens? Is it considered defective because simply because it "should" last longer at 1400 lumens with that specific driver (or not defective, because they never claimed a run time)? I'm neither a flashlight or legal expert so I really don't know.
I still don't understand. Anyways, I'll wait for a review because I'm totally lost. :sigh:
I really hope it's nice and works well though. Who wouldn't love 1400 lumens of Nichia? :)
recDNA
Heck, in imr16340 I would be very happy with 800 lumens as long as my hand isn't burning in 30 seconds and my battery doesn't vent from heat! I'm most concerned that it works properly for a long time and gives higher output than the average 16340 safely. With Nichia 219b CRI we have never before been able to get big output from any pocket sized production lights.
If it really gives us over 1000 lumens with an imr 16340 we'd be lucky to get 10 minutes of runtime. I would only use turbo to show off for a few seconds. I just hope one of the other modes is just right.
SG Hall
Sampson Flat, Sth. Aust.
I agree Wendee, re that last point. Remember that the A6 ( also under the Astrolux s1) is claimed at 1600 lumens but stock is only about 1200. A few mods and it goes close, but not straight out of the box.
I suspect that we will see about 1000 lumens on the Nichia unless you are running a long tube. That's still great in a compact light. I want to jump in on this one, but I'll wait to see if it's an A6 or a comet. [emoji6]
giorgoskok
Users that were able to measure output on the A6 , completely stock , with a good imr battery , reported from 1450-1525 lumens .
I don't think this one will make under 1400 , even with the short tube , but we will have to wait and see...
SG Hall
I don't think this one will make under 1400, even with the short tube , but we will have to wait and see...
1109 with the long tube was estimated on the forum in a review that put the A6 deal together, 1100-1200 on another thread, and 1200+. I have one and it's not any more than that. Nice light though, really well put together and great value.
Re the E14? I like your optimism, and I like surprises. :)
RollerBoySE
Sweden
BangGood is currently offering it at an aggressive pre-order price.
It's labeled Astrolux S41 (still made by Manker and identical to Manker E14).
