This has been an interesting thread to read through. Lots of valid points. My $0.02.
There's no doubt that LED technology has come a long way. And yes, there are some LED throwers that are currently available (using the SBT-90.2) that are nearly able to match the performance as these high grade HID systems. I think it's somewhat flawed to compare a manufacturer like Acebeam and Astrolux to Xevision or Polaron. Their target markets are completely different and thus design philosophies are different as well. I personally would not depend on Acebeam and Astrolux for my lighting duties if I was in a remote location or in a hostile environment where I have to have to have to HAVE TO depend on my light for my own survival. At the same time, I would never purchase Xevision or Polaron lights to take my kids to the park in the evening. Well.... I would if money was no object but I am a flashaholic. And I'm sure if Acebeam and Astrolux had to market their products to the customers that Xevision targets, they would be much more expensive and vice versa if Xevision had to target Acebeam's market.
Having said that though, I have yet to see anyone able to drive any LED hard enough to match the performance of high end HID lights, and do it for an extended period of time. All of them will automatically back off the output after 30 seconds to preserve the life of the LED. It would be interesting to see what all of these companies can come up with if they had to swap markets and design their respective lights for them.
Badtziscool, I agree with some of your points. However, what we can do when discussing strictly performance, rather than use generalized terms like "High Grade HID" and the name brands associated like XeVision/Polarion, we can actually break down the numbers here and see what how the best LED's compare to the current HID's on the market. I believe the numbers will show a very different story than what you are telling.
Polarion PH50 4800 Lumens 1.5K Throw MSRP $1995
Polarion PH40 4000 Lumens 1.2 KM Throw MSRP $2095
XeVision XE-LX50 5300 Lumens 1.49 kM Throw MSRP $2298
XeVison XE-LX70 7500 Lumens 3 KM+ Throw MSRP $2587
XeVision XE-LX70 w/t SuperHead 7500 Lumens? 4.5 KM+Throw MSRP $?
Note LED numbers are Turn on and ANSI @30 seconds. Take note the BLFGT90 will sustain over 4000 lumens operation continuous.
Acebeam K75VN 5200/4800 Lumens 2.64KM Throw MSRP$279
LUMINTOP BLF GT90 7000/4970 Lumens 2.72KM Throw MSRP$349
Astrolux MF05 7000 Lumens? 3 KM Throw MSRP $569 3.1
Couple of points to make here.
(a.) The numbers show that an LED, the
SBT-90.2, is not only able to match some of those "high grade HID's", it can actually exceed some of them, and outthrow by a bit.
(b.) Heat is the biggest issue facing LEDs, and that is being addressed with active cooling now, and it's going to being to become a standard for the highest end lights from now on, more out of necessity than chasing numbers. As cooling gets better, we can slowly chip away at this "sustained output" advantage that
some HID models have.
(c.) I don't consider this to be a "flawed" comparison. Rather, it's taking the best of one technology, and pitting it against another. LED vs HID. We are talking numbers here, and these numbers are not exactly a direct comparison between the different lights, but rather their performance alone. I understand they are two totally different lights, and two different markets, completely. And I also understand that when it comes to mission critical situations, it's the expensive HID's that will be chosen (but for how long). This thread is really more about a reality check to HID manufacturers of how close LED's are getting in terms of sheer performance. Their intended market and who buys what is an entire other subject.
(d.) Not every use case is just about throw distance. Massive amounts of light output at more reasonsable ranges is needed in many situations. The large, multi emitter LED's absolutley destroy all current HIDs on total sustained output. Furthermore, as output get higher and higher with newer multi emitter models, they will be able to start throwing very far due to sheer grunt in output. Single emitters will not be required for 1mil candela plus once the output gets high enough.
With that said, on output and throw, I believe we are just one single emitter, and one good cooling solution away from having a true "HID killer". Give it a few more years, and we'll bump this thread.
