XeRay
It would be cool if there was a short arc bulb that could be used in the FF5. The throw would be insane. I know its possible. I remember when Ra made the Maxablaster, i dont remember if it was him or someone else that also make a handheld shortarc flashlight in a similar size as the FF5.
The ballast would also have to be swapped, a short arc bulb (excited Xenon ONLY inside) and ballast are very much different "animals" than ballasts used for Metal Halide plasma HID. In MH, the Xenon is only used for the initial start up for some few seconds max. In MH HID, after that initial start sequence the excited plasma takes over, being much brighter than only Xenon.
Xenon short ARC in the Maxabeam size systems gets in the ballpark of 20 Lumens per watt, Well designed MH HID also at about 75 watts is about 115 lumens per input bulb watt. At 50 watts close to 110 lumens per watt.
At 35 watts HID, only about 92 lumens per watt.
You can get a much tighter beam with short arc (due to the much smaller arc size) but the Lumens per watt efficiency simply is not there. However, what Xenon Short Arc does well, it does very well.
