Hoosier Light
- Joined
- Sep 15, 2010
- Messages
- 91
Good stuff here. Thanks. Looks like the lesson from your testing is to use high only when really needed.
Runtime on high: Light output seemed to hold steady until about the 27 minute mark where it lost maybe 25% of the original brightness?
It seemed to roughly hold that output level until about the 40 minute mark at which point heat generated from the light significantly dropped and the light output seemed to be about 50% brightness of original.
By around the 45 minute mark the light output seemed about twice as bright as the medium mode.
At 50 minutes, it was barley brighter than the medium mode.
At about one hour the light output was the same as the medium mode.
I noticed around one hour and 17 minutes in, the light output was lower than the medium mode.
And at an hour and 30 minutes the output was the same as the low mode.
Finally, when I checked again at the two hour mark, light output dropped to below one lumen and the resting voltage was .73
These are rough guesses since I lack any testing equipment but maybe soon I will use these as a benchmark to run another test and see if they match up again.
