New Duty Light Reccomendations
BigDogg795
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
_XX_This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
_XX_Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
_XX_I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
_XX_TINY - Every day carry (2-4 inches).
_XX_SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_XX_LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_XX_I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
_XX_I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
_XX_I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
_XX_I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
_XX_I want a light that snaps into a cradle (usually mounted on a wall)
_XX_I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
_XX_I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
_XX_I want search and rescue type illumination (800+ lumens).
_XX_SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
_XX_Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
_XX_Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
_XX_Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_XX_5-20 yards/meters (check out a noise in the backyard)
_XX_30-50 yards/meters (I have a big backyard)
_XX_50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____150+ yards (I am searching from a helicopter)
_XX_30-60 minutes (I have plenty of batteries just ready to be changed)
_XX_90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_XX_Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
_XX_I want a forward clicky (Helpful for momentary activation and signaling).
_XX_I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
_XX_I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
_XX_I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
_XX_I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
_XX_Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
_XX_Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
_XX_IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
_XX_Other CARRIED ON DUTY BELT___________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
_XX_Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
I currently own a PD35 (2014, non-tac 800 lumen), a Streamlight Strion HL if that helps. I guess I'm looking for something that'll be an upgrade to the PD35 and was looking at either a TK35UE or a Nitecore P12GT but wasn't sure how it would compare qualitywise...
peter yetman
North Norfolk UK
There's lots of threads on here for you to find. Look for "Duty Light", LEO Light" etc.
Here's one post that gets well deserved repeats....
Malkoff M91T MD3 with High/Low ring.
Will run on 2 x 18500 rechargeables or 3 x CR123a's.
With the head tight it will always come on in high mode (700 lumens momentary 600 constant), just turn the head slightly (1/16th of a turn is enough) and it will come on in low mode (25 lumens) which is ideal for checking documents etc.
It utilises a tightly focused TIR optic and has ample spill. It will penetrate blacked out windows easily and will illuminate objects at 900+ feet.
For momentary tactical use just position the centre of your thumb pad over the switch, you wont be able to apply enough pressure to switch it onto constant.
It's about the size of a Surefire 9P, 6 1/2" in length, so will tuck under your arm when writing out a citation etc. It will run on High for 45-60 minutes on 3 x CR123a's.
Malkoff's are built like a tank in the USA and benefit from a lifetime warranty.
They also offer a discount to LEO's and their customer service is second to none.
A larger recommendation is the Malkoff Hound Dog XM-L MD4.
It has 1000 lumen output on high and 70-100 lumens on low, it'll illuminate objects out to 1000 feet, it's got a larger head than the M91T and has a longer body that will accept 2 x 18650 batteries or 4 x CR123a's. The Hound Dog MD4 is 8 3/4" long and with the larger head it isn't suitable for being carried on your duty belt at all times.
With a pair of 18650 3500mah batteries you should be able to get about 2 hours runtime on high out of the Hound Dog or about 50 minutes from 4 x CR123's.
A smaller alternative is the M61HOT MD2, which will run on 1 x 18650 or 2 x CR123a's. With the high/Low ring installed it will put out 500+ lumens on High and about 5 lumens on low. It will illuminate objects out to about 600+ feet.
Below is a photo of my Malkoff's showing the three different sizes for comparison.
As far as a Tactical holster is concerned how to you want to be able to position the flashlight?
If it's lens up then a simple Kydex holster will be sufficient, the one below is from Kytex Shooting Gear and they produce a version for duty belts.
For something that allows bezel down carry consider something like the Nitecore NTH30B, which will also carry an extra 18650 battery or 2 x CR123's in a battery Magazine.
This type of holster would probably accept three CR123's in a battery magazine as well. OLight produce fairly inexpensive battery magazines for 2 or 3 CR123's that will fit into the Malkoff flashlights.
Another alternative holster is one that swivels to allow the flashlight to be used whist still in the holster. For example the ESP holster shown below, I think that there is now a USA distributor for them. A suitable one of the MD2/MD3 would be the LHU-14-34. The one below is larger to fit the Surefire Fury bezel.
I would also consider a lanyard for the flashlight so if you have to drop it it'll still be attached to your belt.
I am not affiliated to any of the manufactures mentioned but I am a happy Malkoff customer, I'm also a retired LEO (after 30 years service) who wishes these products were available when I was on the streets!
Any questions, just ask.
Stay safe!!
P
