My current project. Still waiting on a few parts before I can start designing the pill. Basic plan is a Noctigon XP-G2 R5 3C with a Carclo (have both a narrow and a frosted to play with), a 3amp driver and solid brass pill. I haven't decided whether to thread the pill to fit inside the E head (what the heck is this called anyway - it's not a Z44, a Z30?), or just a threaded ring that acts upon the pill to hold it in place. I will remove the built-in reflector on the lathe, so I'll have plenty of room to work with.
This is in an E2D incan defender, I will probably swap out the SF clicky with a McClicky. The SF will probably be fine at 3amps, though.
Once I get this going, I'm considering making a complete custom E-bezel head. The ones like in my photo above seem to be scarce as hens teeth. I like the design because it's small. I don't like the new current SF LED heads that are as long as an 1E body. That is also in the planning stages.
