Shooter21
Jorn why not just sell it instead of killing it?
I guess I'm not sensitive to pwm since i don't see it in mine.That's impressive. So you ran a whole 14500 through the mini too?
I'm hoping to hear someone say that their example the PWM wasn't as noticeable too...
For the greater good Thanks Jorn.Jorn why not just sell it instead of killing it?
Good to hearI guess I'm not sensitive to pwm since i don't see it in mine.
No, havent tested a full run on the mini with tailstanding. I only use that one on max when held in my hand. But this thing is old by now (first version mini with neutral xp-e), and i only run 14500's in it, so i dont think it will die on me anytime soon.That's impressive. So you ran a whole 14500 through the mini too?
Shipping rates in Norway is among the highest in the world. So let's just say it's not worth it for me to send it anywhere (not even across the street) with the postal service. Im not rich, but far from broke , so no problems doing some "public service" trying to burn it with some 14500's. It took 2 14500 in a row, tailstanding. No harm done (that i can see or smell on the light.) It did get hot, i was worried for my 14500'sJorn why not just sell it instead of killing it?
What's the easiest way to detect PWM, would a video camera make it easy to detect it?
I broke down and finally got one after wanting one for a while now and I'm not be able to see pwm on mine, guess I'm just lucky.
This light is AA/14500 sized, no way you'll fit anything bigger. See jorns posts quoted below.Has anyone run this one with li-ions yet?
I know you can with the AAA and AA versions, but has anyone put a 16340 (or even better a 18350 IMR, but that's wishful thinking) in this one?
Maratac torture has started. Since i don't care about the light at all. Ill try to kill it with tailstanding it in high, and run some 14500's trough it.. To see if it burns.... It's really, really hot right now:devil:
It did fine on the first battery, and im now on the second one. Im not going to do more than 2 14500's in a row. All this heat can't be good for my presious 14500's haha. Took 2 temprature sensors from the computer and put one on the head near the led and one under the base of the clip at the bottom. 67celsius at the head and 60 C under the clip. Dont know how accurate theese sensors are. But my hand feels the same thing. Burning hot, even at the tail end The copper spreads the heat really well. The quark mini feels hotter on the head, and not so hot at the tail with 14500's.
Just a note of correction; the XP-E can have a tighter hotspot given the same reflector, but that doesn't mean it can't be paired in such a way as to have a very gentle and floody hotspot, as shown by the LF2-XT and its XP-G like beam pattern.The copper AAA I bought a few months ago (the most recent run) has a XPG-led, with the small reflector the hotspot is rather large. If they put in a XPE-led in this AA version (as in the non-copper version of the Maratac AA rev2) the beam will have a tighter and brighter hotspot than the AAA-version, due to the smaller led-size (=also higher surface brightness) combined with the bigger reflector.
Shine the light on one hand with the fingers out and wave your hand back and forth. It will either show blurred fingers (preferable) or multiples, and if the latter, then the more fingers you see, the better, as it indicates a higher PWM rate.What's the easiest way to detect PWM...?
+1Still thinking about picking one of these up, I just really wish they made a neutral and didn't have potential PWM problems. I wonder if I could swap the guts from an L3 L10 into one... I have two 219 L10s I'm pretty happy with, but that copper body... :lipbite
