gunga
I believe I read that it is only for 14500s. This makes sense because remaining capacity and voltage track well in a 14500 cell but not in nimh.
Good to know - thanks. I couldn't find any info on it anywhere, and the manual is silent on it. I also have an Xtar WK41 (1xAA/14500) as well, and that one has a low battery indicator that works with both 14500 and NiMH cells. I tested another NiMH in the S15R and again, no low battery indicator until the LED dimmed. The voltage was under 1.0V when I took it out to test.I believe I read that it is only for 14500s. This makes sense because remaining capacity and voltage track well in a 14500 cell but not in nimh.
Has anyone tested the moonlight mode runtime of these lights? My S10R pulls about 9 mA from li-ion battery in the moon mode, which would translate into 72 hours assuming 650 mAh battery capacity. I decided to test with S10 and Olight RCR123A li-ion battery and it lasted for about 60 hours until the protection circuit in the battery kicked in.
I personally care less about runtime than lumens output, and a dim moonlight is definitely more useful to me. Actually, the dimmer the better.... but then again S20R moonlight is brighter which would shorten the runtime. On the other hand Olight claims 480 hour runtime.
I tested the Olight S10R with a freshly recharged Olight RCR123A li-ion battery in moonlight mode and it lasted 73 hours.
That would be interesting to see..
Since S20R battery has 4 times the capacity of S10R, it should last for 240 hours, but then again S20R moonlight is brighter which would shorten the runtime. On the other hand Olight claims 480 hour runtime.
Well, my S20R moonlight results are in!
It finally kicked off completely sometime today after I left for work. At the minimum, it lasted at least 17 days (408 hours) and at most 17.5 days (420 hours). Not as much as the ANSI rating would indicate, but then again, I don't know if the charging cradle charged it to a full 4.20 volts either.
Great, now I can actually use the light again for the first time in weeks! :laughing:
No problem.The battery I used was the one that came included with the light, an Olight 2600 mAh cell. That's the same cell listed in the manual for the run time estimates provided by Olight.Great results for this small light. And thanks for sharing.p May I know the capacity of the battery used for the conduct of this test?
