Random Dan
- Joined
- Jun 30, 2012
- Messages
- 1,371
Id love to see what one of these looks like on an 18650 tube. Seems like if you slid the attachment down to the tail end of the head it might still work for deep carry.
So does the clip ride against the rotary dial?
I wouldn't fret about wear on the Roatay mechanism. I've one apart a few times, and they're pretty bomp proof.
P
...My screws holding the clip to the ring keep coming loose but that's probably my fault (I'm super paranoid about stripping the threads). More thoughts to come.
A little bit of medium strength loctite handles that pretty well. Worked for me. But ONLY medium...as I remember it's blue...never use the heavy-duty stuff unless your really sure you never want to remove it!
Here's couple of photos as installed on the rotary tail. I tried it both ways. I have never used a two way clip before so excuse my ignorance when it is apparent.
There are a couple of things I noticed if you like to adjust the output one-handed (my habit).
When I use the light in an underhand position, I adjust it by compressing the tail with my pinky and palm and use my thumb and forefinger to rotate the head/body. Having it attached at the bezel pretty much prevents this.
Conversely, attaching the clip on the rotary end prevents one hand adjustment in the overhand position. There is some adjustment available if you hold it just right but no more than 1/4 turn. I suppose it's no big deal if your always a "two hand adjuster".
Retention pressure in the pictured orientation with bezel-down in pants pocket is only slight. It does hang deeply though and for casually just walking/sitting I don't see it coming out. If you like to do back flips or stand on your head a lot, it'll probably fall out...
Lets just say that runners, rock climbers, cavers, acrobats etc. should consider some kind of lanyard-to-belt-loop or some other secondary form of attachment if they want to hang this configuration in their pocket with the bezel down. Again, this all may be normal for this type of clip...
In bezel-up carry, clipped to the pants pocket, retention is better.
In the attachment config as pictured, the light becomes very useful as a quick and dirty headlamp if you want to attach it to the bill of a ball cap. Retention is pretty good. Again, I would use it on the ball cap for more leisurely activities...car repair, hands-free night walking, stuff like that. In other words, its no replacement for a dedicated headlamp but will suffice in a pinch as long as you have the clip attached on the rotary tail. When attached to the bezel, retention is not sufficient to hold it onto the bill.
The only concern I have as attached to the rotary tail: is this too stressful on the rotary mechanism when the clip is pushed and pulled, thereby pushing pulling the rotary cap with it? Right now I feel it is not but it is one consideration I suppose.
