kaichu dento
Emitters don't make rings - improper fitting makes rings and if you have a light showing rings, the fitment between the reflector and emitter needs to be adjusted.
My early 119 Haiku shows no ringiness whatsoever and it's also worth noting that some artifacts showing up in pictures are not visible in actual usage. If you've found pictures showing what you feel to be a problem then you might try sending a PM to the taker of those shots, or try contacting Don McGizmo directly - he's very congenial to talk to and not only has owned every iteration of Haiku out there, he made them.
