Is it high CRI?
Is it high CRI?
I do...lanterns.damn, I have no osram based lights.
Is it high CRI?
Nitecore - you must stop this - you are breaking my wallet
This is a very cool development. I'm wondering if lumen output will be about the same level?
Well, best their cool white can do is 85lm at 350mA, so their Vf (of which I have no idea what is) would have to be significantly lower than most other white LED's for the efficiency to be about the same. I cannot find any Vf specs for the "Plus" series, only the regular "Gold Dragon".
:welcome::welcome::welcome::welcome:LOL.........yup, I believe it's called lurking. And here I am at what, 15 posts and not a single welcome. Thanks for the compliment tho...........
selfbuilt will have some more testing to do in terms of output / runtimes...Nitecore - you must stop this - you are breaking my wallet
The datasheets are at the bottom of each of the Golden DRAGON Plus product group pages.Well, best their cool white can do is 85lm at 350mA, so their Vf (of which I have no idea what is) would have to be significantly lower than most other white LED's for the efficiency to be about the same. I cannot find any Vf specs for the "Plus" series, only the regular "Gold Dragon".
What does this mean? Does it mean the max output is only 105 lumen?The datasheets are at the bottom of each of the Golden DRAGON Plus product group pages.
For all 3 Golden DRAGON Plus products:
LCW W5AM (68 lumen)
LW W5AM (71 lumen)
LUW W5AM (105 lumen)
the forward voltage (according to the data sheets) appears to be 2.7/3.2/3.8 V (Min/Typ/Max) at 350mA.
The spec sheet that I found says 105 lumen @350 mA, but the LED can take from 100 to 1000 mA of forward current.What does this mean? Does it mean the max output is only 105 lumen?
ok thanks.The spec sheet that I found says 105 lumen @350 mA, but the LED can take from 100 to 1000 mA of forward current.
Page 8 of the data sheet shows different brightness groups, showing lumen ranges from 71 to 150 lumens.
I think you haven't had a "welcome to CPF" because your posts seem to indicate to most other people that you're a very senior and long time CPFer. Glad to have you here!
