I just got my GD NDI from 4Sevens. This isn't a review, but just my first impressions.
Don't worry about the beam. It isn't blue. Mine is warmer in fact than my LiteFlux LF5XT which is cool white. The beam in fact has a light yellow band surrounding the creamy white hotspot. This band blends seamlessly into the hotspot and into the surronding slightly cooler larger spill area. There is no black donut around the hotspot like with the old Q5; just the relatively wide yellow band which becomes hardly noticable at a distance of 10 feet or more.
(Sorry I am not a photographer. I wish I could give you beamshots)
Overall the smoothness of the beam is much improved over the old NDI Q5, but not quite as smooth, IMO, as the LF5XT. If it weren't for the light yellow band, I would probably say the GD was just as good.
As far as color rendition, I don't see much difference between the GD and the R2 or the Q5. They all do reasonably well except with reds, where they all seem to be lacking compared to my McGizmo Sundrop. Maximum brightness seems on the GD seems to be very close to the Q5 NDI. I used 14500 cells for all my comparisons, although I did try Eneloops to see if it caused any color shift in the outputs. It didn't.
There are some suprise improvements I didn't expect with the new Nitecore NDI:
1. There is much more aggressive knurling on the new GD NDI. I don't have a D10 with which to compare, but I'll bet it is close.
2. The threads are much improved; much smoother; now anodized. Mine was even properly lubed.
3. The contact area on the inside of the head is now like that found on the D10/Ex10. Instead of a fixed contact on the board, it has the floating brass ring contact supported by a spring. I guess this will increase the life of the light by avoiding too much direct pressure on the board and its previously fixed contact area by the tightening of the head. The only problem I found from this arrangement is it seems easier to get the light to accidentally strobe as you switch into user definded mode, particularly if you loosen the head slowly. If you always remember to loosen quickly, no problems. I twisted the ring a bit to see if this would fix this problem; no luck.
4. The switch appears the same but seems much firmer and sturdier than the old Q5 switch. Still, they give you a spare. Previously, they gave 2 spares.
5. Because the GD is much smaller than the Q5 emitter, the reflector cone seems a bit deeper since the cut out for the LED at the end of the cone is smaller,too. However, there is no noticeable difference in spill between the new and the old.
