Order:
- Quantity of Regulators: 1
-- Standard Model Regulator: 1 @ $97.00
- Quantity of User Supplied Sockets: 1 Kiu socket
- Shipping: $7.00
Regulator Model: (standard)
Bulb Data:
Bulb Type (manufacturer, model): Phillips 5761
Maximum Bulb Voltage (RMS full output): 7.2V
Medium Bulb Voltage 4.5V
Minimum Bulb Voltage (RMS fully dimmed): 2.0V
Battery Management:
Can be specified in one of two ways,
either
- Battery Chemistry: Li-ion
- Number of Cells: 3
or
- Maximum Battery Voltage: 12.6V fully charged
- Nominal Battery Voltage: Whatever you recommend
- Minimum Battery Voltage: 9.3V battery cut off - is this the same as your
Equation C assumes that cells are fairly well matched but continues till one of them drops to minimum. This is the default choice.
Socket:
Basic, Osram Socket Upgrade, User Provided (specify):
I have already furnished my own KIU socket with KIU metric posts and
you have already recvd my KIU socket. I would like a little extra length in the
socket leads like CPF member Donn has mentioned since I have all three sizes
of reflectors to choose from Litho123's HS 2" plus Fm 2.5" and Delghi 3".
Other Features:
Click to Memory Level (if not then Max)
Double click to Max Voltage
Press from off to Min voltage
Press from on to Ramp - alternates up/down
Triple click to Mid Voltage (halfway between minimum and maximum voltage)
Five clicks to Lockout
Soft Start - I want the longest soft start available
Temperature Shutdown at 50C
OneLevel Mode - Turns light on/off with click or press. Uses memory level if available otherwise max voltage.
VariLevel Mode - On/off with click. on to low from off with press. brighten/dims with press while on, alternating direction. hundreds of small steps, appears continuous.
MultiLevel Mode - Similar to VariLevel but instead of hundreds of tiny steps does it in 3 to 7 large steps. Specify how many steps. Steps are equal in voltage from VLO to VHI.
At least one of the above three modes must be specified, but two or all three can be enabled. When more than one mode is programmed into the regulator then a quadclick while the light is on rotates to the next mode. The order of modes is OneLevel, VariLevel, MultiLevel. The default level mode is also specified at build time. This default takes effect at power applied (eg when batteries are installed).
I will want all three modes.
Lockout Mode is a bit different. When this mode is entered only the click sequence to take it out of lockout mode works. The number of clicks to engage lockout mode can be selected. The default is 5.
default is okay with me.
Lockout Mode Basic Flashlight Option - if this option is selected, while the light is in lockout mode it will behave as a basic single level flashlight. The voltage level is also selected and is usually a low level on high powered lights. If this option is not selected then lockout mode does nothing and the flashlight appears to be broken until unlocked. With this option it appears to be a single level light at whatever light level / voltage was programmed.
Voltage i want is whatever gets me the equivilant of a stock 2D MAG
PayPal sent
