I used the washer from the P20 host. It appears to have the same ID but a larger OD.
Ah ok, hopefully we're on our way to solving the OP's problem.
Sorry for the difficulty. Most likely the stronger spring on the v5 is combining with a longer battery and forcing the v5 neg contact ring off of the hosts neg contact surface.
I'll need to ship you a spring washer. In the meantime do you have a spring washer or shorter battery to try?
Update
Our original testing showed that the P20 Unified Host benefited from spring washers and the Z35 did not. But this testing was based on a single set of batteries that have not shown to be representative. Longer batteries also benefit from spring washers on the Z35.
We are now shipping free spring washer kits to all Z35 owners.
When yours arrives, please remove your current kit and follow these steps:
insert spring washer
insert dropin (not included)
insert one (thinner) oring
insert lens
insert second (thinner) oring
thread in and tighten bezel ring
test
Here you goHi,
Quick question : is the Z70 compatible with the 18350 and 18650 extender ? It will not be pretty but it's useful for extended runtime.
Could someone post picture of the Z70 and Z35 next to a classic 6p or moddoolar bodies ?
Thank you.
Welcome to CPF!Can any p60 drop in be used with the z35 host or do you need to use an oveready p60 drop in with it?
I have a sportac p60 drop in currently that I need to use, will this work in the z35 host?
Thanks
I can get a pic tomorrow. I ran my Z70 with a tricap for a few days but it is longer overall than with Z41 type tail cap.Has anyone ever used a Malkoff Tricap on one of these? If so, can you post a photo?
