PEAK LED SOLUTIONS
PACIFIC TECH NOTES
26 FEB 2006
Our goal in producing the Pacific line of Peak LED Solutions flashlights was to use a single, low cost, generic alkaline AAA battery in a High Power operation, which would duplicate the output and run time of the Peak 7 LED Ultra Power McKinley using a single CR123A lithium battery. The use of optional battery packs to tailor the light to different applications instead of buying different lights was also a consumer value goal.
Designing a high output LED flashlight for the alkaline AAA battery with good run time is a challenge. The alkaline AAA battery specifications call for a continuous maxium output of 30 mA per hour. AAA battery capacity is determined at a constant draw at 25 mA. Higher current draws can severely decrease the overall capacity of the battery by as much as one third.
The current draw from the 1.5 volt alkaline AAA battery for the High Power Pacific is 210 mA. This is 7 times the recommended maximum constant current output for this type of battery. (All numbers given are nominal, subject to individual differences of electronic components and batteries.) As a reference, an unregulated single 5 mm LED single alkaline AAA flashlight that outputs 43 foot candles will draw 240 mA. The Peak LED Solutions 3 LED Ultra Power Matterhorn that outputs 110 foot candles has a draw of 280 mA.
Our testing procedure for the Pacific line of Peak LED Solutions flashlights:
A random sample of 20 completed High Power heads was selected and tested with 2 alkaline AAA batteries, (3 volts), for light output. The output range was from 284 foot candles to a high of 335 foot candles. A Pacific head with an output of 313 foot candles was chosen as a test standard. All batteries used in our testing are low cost generic brands. Premium or brand name batteries may give 5 % to 10 % increase in run time, but in our opinion do not justify the increased cost.
Each run is for 24 hours except for the alkaline AA which was allowed to run longer. More test runs will follow in this thread as they are completed. The AA and AAA battery tests will include three types of batteries in three types of battery compartments, for a total of 9 runs for the Pacific High Power series. Plus a CR-2 lithium battery test. We do not recommend the Li-on battery of over 3 volts output in the Pacific.
The test equipment is an Extech Light Meter using their Data Acquisition Program monitored by a HP Pavilion computer, and saved in Microsoft Excel. Current battery draw measurements are taken with an Extech Digital Multi-meter by measuring the voltage drop across a one-tenth ohm one per-cent 3 watt resistor.
The electronics for the Pacific were designed for the requirements of the Luxeon LED. This electronics package will not reliably monitor the battery condition of multiple 5 mm LED systems. As a result the output is erratic and will only be used in the Pacific and other future similar projects. You will note that in some low cost 1 watt competitive flashlights, that they can drop up to 25% of initial output during the first 10 minutes of constant run, and may be dead or in "moon mode" light output after only about 90 minutes. The Peak LED Solutions Pacific with a single alkaline AAA at 10 minutes has a drop of only 5%. And at one hour of continuous run the light output drop is only 13%. The electronics in the Pacific maintains a relatively flat output until it recognizes that the battery can no longer supply full power, then it goes into a battery saver operating mode. This changeover normally takes only 2 seconds or less. This is not what you may be used to in reference as to "moon mode" operation, (less than 5 foot candles output). In the battery saver operating mode, the new output is 50% of the original start-up output. And then has a 'long tail' of many hours of useful light output. After 6 hours of constant run, the single alkaline AAA Pacific High Power has more light output than any single 5 mm single alkaline AAA LED flashlight at start-up. And some are totally dead at just over 6 hours.
Test results, single alkaline AAA battery, Pacific High Power:
Start 208 cP Drop Output % Drop Hours
10 minutes 198 cP 10 cP 5%
30 minutes 189 cP 19 cP 9%
60 minutes 182 cP 26 cP 13% 1 hour
104 minutes 175 cP 33 cP 16%
105 minutes 108 cP 100 cP 48%
120 minutes 106 cP 102 cP 49% 2 hours
180 minutes 91 cP 117 cP 56% 3 hours
240 minutes 79 cP 129 cP 62% 4 hours
300 minutes 67 cP 141 cP 68% 5 hours
360 minutes 46 cP 162 cP 78% 6 hours
420 minutes 36 cP 172 cP 83% 7 hours
480 minutes 28 cP 180 cP 87% 8 hours
540 minutes 23 cP 185 cP 89% 9 hours
600 minutes 18 cP 190 cP 91% 10 hours
720 minutes 12 cP 196 cP 94% 12 hours
900 minutes 7 cP 201 cP 97% 15 hours
1080 minutes 4 cP 204 cP 98% 18 hours
1440 minutes 2 cP 206 cP 99% 24 hours
At 9 hours the single alkaline AAA Pacific High Power produced as much light as the original single 5 mm single alkaline AAA LED flashlight of 4 years ago and at 12 hours the Pacific equals the light output of the original single 5 mm single alkaline AA LED flashlight of 5 years ago. Typical "moon mode" output is achieved at about 18 hours of constant running.
We will be adding additional test results as they are processed.
Thank you
PACIFIC TECH NOTES
26 FEB 2006
Thank you
