Currently, in my opinion, the best option* is to remove whole electronics from the battery pack and connect battery holder directly to the headlamp wires - the head also have the protection circuit based on voltage control (it's quite precisely set for 3,0V and it's switching to the rescue mode so you can use even unprotected cells). The benefit of this solution is that the lamp will use the whole capacity of the cell that you are using - instead of "calculated capacity" used by Petzl's electronics.
I mean it is not neccessaryFor me it is not recommended to place the batteries on my head.
Hi Szemhazai. I have followed your publications and the your last opinion surprised me. Can you explain please what will happened with the custom (OS by Petzl) profiles if you chose this new approach (to remove whole electronics from the battery pack). Actually I'm not sure where the profile information is contained, but if it is in the battery pack I cannot understand how this approach will work at all?Currently, in my opinion, the best option* is to remove whole electronics from the battery pack and connect battery holder directly to the headlamp wires - the head also have the protection circuit based on voltage control (it's quite precisely set for 3,0V and it's switching to the rescue mode so you can use even unprotected cells). The benefit of this solution is that the lamp will use the whole capacity of the cell that you are using - instead of "calculated capacity" used by Petzl's electronics.
Great review! I bought a Nao back in mid Oct and love it. Sure it has it's flaws (namely the fog issue discussed above and also when breathing), but that stuff is expected from a first generation product. I'm not quite sure how Petzl and others will rectify the reactive/fog issue, but it sure would be nice if the sensor could detect that you are in a foggy/humid environment, and compensate for it. Things to look forward to I guess..
Sohl - it can be done, but I don't know if the shipping rates and delivery time will not kill the whole idea.
International priority mail PL-SE ~10 Euro, delivery time about 2 weeks.
Hi guys,
Petzl states in the literature that the battery alone(without the plastic container) is available but I haven't seen it sold anywhere except when packaged as part of the expensive pack. The literature says to reference part E36A20.
chasm22
New user.. digging up an old thread - please go easy!
I have just ordered a 3450mah replacement for my original Nao *link removed
I am sure I'll be able to charge this once it fitted to the Nao battery housing, but it would be great to be able to charge both the old and new batteries at the same time. Is there a charger available (ideally USB or 12V car fitting) that can take one of these batteries ? The obviously dont go in standard charger due to the electronics/connector.
