Thanks Niteowl, and yes, the ROP will indeed fit LightEdge's small opening reflectors. I'll also let you guys on a little secret. I been using the low power ROP bulb + seven AAs, and it's almost as bright as the Hi power bulb.
I'm sure this will shorten the life of the bulb, but it's been about three days of play with it, and it seems ok. I also tested the Hi power bulb + seven AAs, and the light is just sheer devastating. The batteries used are hot off the charger too, so voltage should be slightly higher. Using 7 Sanyo 2500mAH. These bulbs can really hang! Can anyone calculate the lumens with these setup?
Also i been using a whooping 16.8volts on those GE 12v bulbs pictured above, and these bulb will take the punishment. Although the heat generated is starting to darken the opening / hole on my test lightedge reflector.
Dang! I really need to learn how to calculate lumens.
Niteowl said:
NT, sounds like you got the big bottle, got a lot of frosting to do, eh?
Warhoggie, does the reflector you're using got the little hole (no cam) in it? It look like the Pelican bulbs will work with the reflector I got from Light Edge if it does. I'm going to try the ROP with a 6C Mag.
I put together a 3x123 for a relative and used the Mag krypton 6D bulb. I used the 6D so it'd last as she won't need a blaster, just something dependable for the truck. The frosted bulb finished it off nicely, got rave reviews.
Again, great idea Warhoggie! Oh yes, nice pics.
NikolaTesla, Yes, I did make sure there were ventilation. You are also correct. These procedures are not for kids or anyone who can't or won't follow rules safely. It is best to slow down, be prepared and take your time through the entire process.
NikolaTesla said:
That stuff from Michael's - Armour Etch. Played havoc with my sinus. I have a bench with exhaust hood I use next time. That HF stuff is not kid stuff even in gel/paste. It do work but rather be safe than sorry. Florine and Chlorine are super active and will work havoc on your sinus. I got a few whiffs out of that bottle and it was more than I care for. Maybe you had good airflow/ ventilation by you.
