Programmable RGB LED Strips For Amazing Lighting Effects
ledbe
Vendor
Hi, if you want to install some SMD LED Strips with amazing lighting effects, I will recommend the programmable RGB LED Strips.
Link: https://www.ledbe.com/addressable-led-strips
1) WS2812B Individually Addressable RGB 5050 LED Strips DC5V
this type of Programmable LED Strips with 5050 RGB SMD LEDs as the light source and built-in WS2812B ICs for individually addressable control. the IC controls the RGB LED to achieve static effects, chasing effects, special effects, each LED has its own color and brightness for 256 brightness display and 24-bit color display.
you can take the 30 LEDs, 60LEDs, 74LEDs, 96LEDs, 100LEDs and 144LEDs per meter,
black and white colors of PCB boards are available,
IP30 non-waterproof, IP65 coating waterproof and IP67 silicone tube waterproof available.
the LED Strips come with 3-pin JST-SM Connectors, easy to connect to a Pixel LED Controller to achieve thousands of amazing lighting effects, like curtain-up, flow water, raindrop, jump flash and other hundreds of lighting effects. you can edit the animation effect by Coreldraw, Flash or LEDEdit.
ledbe
Vendor
DC5V WS2812B Ambient Lighting Kit for PC Screen, 1M and 2M lengths available. price from $17/set only.
Features:
  • Model: AMB Light Kit
  • Working Voltage: DC5V
  • LED Type: WS2812B IC
  • LED Quantity: 48PCS/M
  • Length: 1M(For 14 To 19 Inch), 2M(For 20 To 40 Inch)
  • Colors: 16 Million Colors
  • Brightness Adjustable From 1% To 100%
  • Built-in Microphone For Voice & Music Control
  • Only Supports Window Operating System
  • Software: Beelight
  • 6 Kinds Of Static Modes And 9 Dynamic Modes Available
  • Built-in 8 Music Effects And 180 Non-music Dynamic Effects
  • Power Plug: US, EU, AU, UK
  • 2 Years Warranty
ledbe
Vendor
Check the RGBIC LED Strip Kits, 5M, 10M, 15M and 20M versions available, the kit comes with RGBIC LED Strips, Controller, RF Remote Control and LED Power Supply, easy to install and light up, can be controlled by smartphone APP or RF Remote Control. built-in MIC, allows the Controller can fully adapt to the music rhythm.
ledbe
Vendor
The WS2812B LED Christmas Tree Light String, which uses 400PCS high quality and bright LEDs as the light source on 20PCS String Lights, there are 3 types of lengths available, 1.5M, 1.8M and 2.1M available, can be controlled by RF Remote and APP. various static effects, 11 dynamic effects and multiple animation gallery effects available in the APP, you can choose different animations and select multiple different animations to play in a loop. support input text and DIY the effects you want. the microphone can read the music on the phone and also capture the external sound, there are 6 music modes available, you can set the specific time of light string ON/OFF and the controller will save your last mode setting and there is no need to reset the mode again.
