- Joined
- Jul 15, 2021
- Messages
- 38
The WS2814 RGBW Addressable LED Strips are available, white and black PCB board available, use WS2814 smart IC to control the 5050 SMD LEDs, one IC controls 3PCS LEDs, the LED includes white, blue, red and green chips to achieve 256 brightness and 24 bit color. every 3 LEDs can be cut off. there are two white products available, warm white and cool white, the presence of white can make the RGBIC LED Strips more perfect, more energy-efficient and less heat consumption. can work with SP617E Bluetooth Controller[/URL], Raspberry PI 3, UNO R3, etc to light up RGB rainbow color, pure white light chasing or pure white static effects. both ends with 3P JST-SM connectors, you can continue to extend or cut at both ends. there are 3 types of waterproof products available, IP20 non-waterproof, IP65 coated waterproof and IP67 silicone tube waterproof. the back of IP20 and IP65 with double-sided adhesive tape, easy to take off the protector paper and stick on the place that you want to install. IP67 products should use screws and clips to mount for indoor and outdoor applications. you can use the WS2814 RGBIC LED Strips to make LED screens, Advertising Boards for Hotels, KTV, Bars, Signs, Christmas Or Weddings, etc.
Link: https://www.ledbe.com/12-24v-ws2814-rgbw-rgbic-led-strips-16.4ft
