U
user1016
Guest
I have a Maglite that was done up for me with a Seoul P7 LED many years ago, however I discovered after doing a runtime test on it that the LED appears to be failing. The P7 only maintains full brightness around 900lm for about 30 seconds before it begins dropping slowly to about 25% after about 3 minutes (tested with standard 1.5v batteries. The mod appears to be soldered into the lampholder and the switch itself seems to have been adhered permanently with some kind of white stuff. I popped the button out and unscrewed it; the switch itself beneath the button can technically come out, but it has two red wires that are attached to a separate area that is the lamphead, which does not come free.
Would anyone here be able to shed some light on whether or not it could be replaced based on the photo? The maglite itself is a bit unique and was part of a matte-finish production run from Australia in the late 2000s, so I'm hesitant to dispose of it unless there is absolutely no other option. I reached out to the original modder to see if they could offer some advice but I'm yet to hear back from them.
