Here's one that was daunting at first.
The 2aaa HIPCO penlight.
I haven't really looked up it's age at this point. Between long hours at work and the curiosity to get it going put that off for now. (Edit: Flashlight Museum dates it 1950 and calls it nickle plated; end edit)
It did not work at first. The usual poke and prod with my circuit tester was out due to the small size of the body.
First things first I thought. How does it conduct electricity?
It took a light up magnifier to even see what was going on.
The lit magnifier and dental pick used.
I used the Coast G25 inspection light for this pic.
Deep down inside is a device that moves the battery towards the bulb to make contact with the #224 bulb.
A sorta diagram
The rest of the picture.
The spring keeps the bulb pressed against the battery as it also keeps the bulbs globe protruding from the front of the light.
So I insert two brand new batteries after testing the bulb and nothing. Not even a flicker. Bulb ok, batteries ok. So another pair of cells and a #222 were tried. Still nothing.
Dratz.
Test time. But nothing I have fits inside the body.
Luckily the wife has some silver wire in stock...
Mini probe to the rescue.
Carefully I touched various areas and heard a loud "beep" each time.
Hmph!! What could it be?
After trying various cells I figured perhaps cell length plays a role. Previously I had noted my usual Radio Shacks are just a whisker shorter than others.
And that lithiums are 3 whiskers longer than others. But...
I only had 1 aaa lithium in my entire house.
After checking a couple dozen small lights I have no idea where I used all but one from 2-4 packs...
Perhaps some Eneloop Pro?
Viola!!!!!
Woohoo!!!
Then noticing it flickers easily I decided the switch slides too easily.
Taking a right angle dental pick to the pair of ears holding the switch cover to the inside, I poked it towards the body to pinch it together tighter.
Slider no longer moves so easily.
Now to ensure the light stays on I just hold the switch forward while in use. Gravity allows the battery weight to the move the switch assembly away from the bulb very easily. But it's working and working well.
It works on the same principle as this old Burgess...
This one requires you hold it pressed forward for best results.
Makes it impractical for hands free use though.
Eh, hopefully at some point I'll figure out why alkalines won't fire this light. Until then it's a fine addition to my cup penlights....
It's in fine company with a Wildwood, a Burgess, a few modern LED inkpen/ flashlights and an Icon Solo.
