So this is a bigger announcement than I originally let on. Due to the circumstances I am going to release this a little different than I have in the past. There will be two variants of the Victor released at once. I only have 24 bodies and limited time to release and sell and I figured if I released the regular Victor and then sprung the more powerful version on you as your lights were in route you'd wring my neck. So the two models being released today are the Victor and the Victor Enthusiast. I have managed to get significantly more power out of this platform. Here was my other dilemma. I wasn't sure which light you all would want more. So what I have done is build out a few of both and prepared all the parts that I would need for final assembly of the rest. This way all the lights can be allocated according to your wishes. The built lights show in stock. If it says backordered you are safe to order and it will be built out to your specs shortly. I will shut down the ability to purchase on backorder as soon as I have filled the available 24 spots.
very nice job
So more powerful you say?
The regular Victor is best thought of as a DEFT-X without the bright-work and slightly higher performance. Typical performance is 1,050,000cd.
- Specifications
- -1,050,000cd
- -Direct to copper bonded Cree XPG2 Neutral tint
- -Runs on 3 18650 Lithium-ion cells. Recommend Orbtronic "Protected 3400mAh NCR18650B" or similar "Protected" cell for maximum runtimes.
- -564 grams without batteries/aprx 695 grams with batteries
- -Length 205mm x 75mm(head diameter)
- -6 level light output plus strobe
- -Runtime aprx 2 1/2-3 hrs on high
- -Forward clicky rear switch allows for mode selection before light powered on.
Now for the Enthusiast model
The Victor Enthusiast is the longest throwing LED flashlight in the world. It builds on the legendary DEFT-X platform with several enhancements that allow this light to have searing performance. This is a hyper light with every aspect taken to the current limits of technology. Improvements in the Enthusiast model are a new super high conductivity copper LED base with the LED mounting plate directly soldered, tripple binned LEDs, heavy gauge wires, top binned lenses, and a boosted driver. Performance now reaches an unbelievable
1.3 million candela typical!!!
- Specifications
- -1,300,000cd
- -Direct to copper bonded Cree XPG2 S4 Neutral tint
- -584 grams without batteries/aprx 718 grams with batteries
- -Runtime aprx 2hrs on high
