Yesterday, while at Lowes they had the 6 volt (2x123) version for $25. I went there looking to buy some SureFire batteries but they had none, so I bought the flashlight.
It's pretty bright and has a broad, conical beam so you get a good 150 feet of punch forward through while lighting up a broad area well. It claims two hour run time on a pair of Energizer 123 cells. Being it has 3 LED's gulping from the batteries I'd say it definitely steps down. Machining is good and grip is decent.
Both ends come off and the tailcap is serviceable but the head end is not (without some inginuity). It's $25 so I do not expect it to be but so robust. The head end has some cooling fins and it gets fairly warm after a couple minutes on high. A spring mounted plastic button between the head and battery tends to isolate heat away from the battery some. In other words the heat is more easily conducted to the outside of the head so you don't get the senses you are carrying a hand grenade with the pin pulled like some really bright flashlights of this size. The crenalations make for a good kubatan without being pocket shredders.
I removed the supplied clip because it has ears that protrude to the point of annoying when hand holding cigar grip or overhand. It fits pretty loose so it will probably pop off anyway. I liked the tailcap where about 1/3 of the shoulder is well the button for ease of use from the short travel, soft press button. Momentary is easy with enough travel between off and click to not accidently click it, but to click travel isn't very far either. Overall a positive experience in activating for moment or click. It tailstands on a solid surface. But on a surface with a say, table cloth it tends to lean towards the lower part of the shoulder and fall over.
A rapid click and half press gives a rapid flasher. Half press it to find hi, med or low then press for on with about a half second to a full second between presses. Easy enough to get used to if this is your EDC. I could not find settings numbers so I will guess at what I saw. Medium appears to be 50-60% and low about 25-30%. I liked medium.
One thing about the tacticool white beam is there is not really a defined spot, but instead a really nice combination of throw and spread instead of a distinct wall of light from a flooder light. So you get the option of viewing objects at a distance while lighting up everything in your peripherals pretty evenly. To me the beam is the charm of this light as there are no visible Mickey Mouse look from the 3 emitters in a triangle. Now unlike the 2aa where you can hold the on button to achieve better throw or spill, this one seems fixed. If it isn't I have not figured out how to adjust it, yet did not have an urge to do so as the beam is pretty good from default.
Will it outlast a SureFire or Elzetta? I doubt it but for $25 you can feel comfortable giving it away to a friend or family. This is another 'even bad lights aint bad this days' flashlight.
Compared to a 6P and ProTac
The 3 LED's, with one being dedicated flooder. Nice touch.
The tailcap cutout. Another nice touch in my view.
A beam shot.
Shed in the far distance is about 300 feet.
