VidPro
NewBie said:Yes, the valve has ruptured many, many times for me, or been consumed in the fireball blasts I've had on a few test runs.
I could not get the venting/explosions to occur outside a flashlight, with bare cells. I did get 3 for 3 venting/bursts inside a PM6, with mis-matched cells. I could not get venting to occur with the BS ZTS tested "matched" cells. I could not get the venting to occur on days where the outside ambient temperature was above 85F. I did get 3 for 3 ventings to occur when I wrapped the cells in aluminum, much like the aluminum body of a flashlight.
See this thread for a video of an extremely minor venting video:
http://candlepowerforums.com/vb/showthread.php?p=1497172
As far as testing single cell scenarios, at a later date you may be able to talk me into it, if you pay for the cells. Right now I've been busy running tests every night and on the weekends for the past month, and they are still in process.
well i can only sumarise your doing all the hard work.
so far mismatching seems to be a bad idea just dont know why exactally yet.
how many have NOT had a problem?
"I could not get the venting to occur on days where the outside ambient temperature was above 85F"
HMMMMM, and you noticed the internal cell heat protectors kicking in when drawing to much current.
COULD the internal heat protector be kicking in Faster when the temps outside are higher? does it shutdown more often when the temps are higher? or is the discharge during high temps the same as when cool outside.
cause the PCT isnt really ON the cells roll, so to speak, its above it enough that it can be effected by external temps. and its on the metal of the can, and all that, its not like its in the middle of the real problem
