Wow that's amazing! I'll be it gets too hot to hold in less then a minute though haha.
Everything this size with performance in this vicinity gets too hot in less than a min hahahha
Are the SBT90 specs close for the Amutorch SD2vn and Amutorch VG10vn? Trying to decide which one to go with.
Thanks Vinh! I was torn between the too but went with the VG10vn.I am not sure yet but VG10 will thorw more for sure. But if I can only have one I will take SD2vn. The size is so appealing and it has good looks too.
Why can't the Olight Warrior X Pro be modded with the SBT90 LED?
Damn that Thrunite is insane. You should get some of the latest 20A Vapcell 14500 and 12A Shockli 14500. Will ptobably push it up another 25%
Surprised you haven't tried putting one in the micro gtvn yet.
De-Dome = Peeling off the silicone like soft dome = greenish neutral tint with max led die exposure and reduced beam angle, ~ 5-10% lumen drop but about 50-70% increased intensity
Shave Dome = Slicing off the silicone like soft dome = Retain factory tint = Retain factory tint, 10% loss in lumen but about 30-50% increased in intensity
De-Lens = Removing a glass box cover over the LED die = more pure white tint + ~5% increased in lumen
SD2vn is appealing size for a 21700 light, looks very pocket friendlyI am not sure yet but VG10 will thorw more for sure. But if I can only have one I will take SD2vn. The size is so appealing and it has good looks too.
Does the build have room for extra thick copper heat sinking?
..and, reverse switch function, correct?
Thanks!
LInk me
I found a way to greatly reduce the ring effect with some LEDs in a smooth reflector such as BLF GTvn woth CFT90.
Use a black permanet marker and color around the reflector hole wall. Be careful not to smear on the reflector. Cheers!!!
Here is the Vapcell 14500 H10.
Here is the Shockli 14500 12A cell, which I haven't bought. It should be better performing than the Vapcell H10 but we do not have a direct comparison.
